ducatipaso.org • View topic - My white Paso
It is currently Sun Nov 01, 2026 2:53 pm
 Post subject: My white Paso
PostPosted: Sat Feb 14, 2009 5:56 pm
This is my white 1990 750 Paso. It used to be red with red seat. But the fairings where damaged when I bought it, so I repaired the fairings and brought it to the paint shop to spray it white.
Things I changed:
- 916 Front forks
- 916 front wheel and brakes
- Renthal handle bar
- supersport rear wheel and brake
- Mikuni supersport carbs
- K&N Filters
916 front end:
To make the 916 forks fit my paso, I had to use Monster yokes, because the diameter of the center pin of the 916 forks is to large for the chassis of the Paso. So I bought a set of Monster yokes.
The holes in the upper yoke are milled to 53mm(were 50mm), the lower yoke has a 0,5mm spacer to clamp the forks. Clip ons cannot be fitted to the Paso, because of the tank, so I had to buy a normal handle bar. The 916 forks have adjustment knobs on the top of them, so I could fit the handle bar in a normal way. So a friendly member of Ducati club Netherlands made me a set of offset handle bar clamps.
The wheels and brakes fit the forks perfectly because the width of the monster and 916 forks are the same. And off course I had to buy a carbon fender.
Rear wheel
I bought a rear wheel from a 750 supersport or monster(2nd generation wheel) with the brake calliper and brake adapter.
The brake adapter had to be milled down by 18mm and the hole had to be enlarged from 17mm to 20mm. I had to make a bolt(M10) with a bush in the swing arm to block the adapter from turning(it's a bit rusty now, I will replace it with a stainless one)
On the sprocket side of the rear wheel, the sprocket adapter is milled down a bit. The center bushing had to be remade bacause of the larger diameter of the spindle. The wheel brearing have been replaced by 6204 2RS bearings. The axle between the two wheel bearings had to be replaced by a new axle with an inner diameter of 20 mm instead of 17mm.
[b]Mikunu carbs]
I replaced the original carbs with Mikunu ones from a 750 Supersport or Monster. It's easy to replace them, I only had to modify gas cable. The original air box won't fit at the mikuni carbs, so i fitted K&N's RU-0800 with some plumbing to fit them under the tank.
Still have to do a lot of work to make it rideable. It won't start right now, it hasn't started for two years now.
If you have any questions, just ask.
 Post subject: Re: My white Paso
PostPosted: Sat Feb 14, 2009 6:16 pm
note that the fork is 3-3,5cm shorter than the original one (of what I remember) and the offset of the Monster triple clamps is also quite a bit different compared to the Paso, meaning that this is quite a big change in geometry. Is that on purpose ?
Don`t the large fork tubes hit the front side of the tank when turning left or right ?
PostPosted: Sun Feb 15, 2009 12:06 pm
Yes it is a little shorter. And the offset may be different, I will find out if this is a negative thing when I ride it. The two bolts on the picture prevent the fork to hit the tank. I can rotate my front end about 45 degrees.
PostPosted: Sun Feb 15, 2009 12:28 pm
there`s a misunderstanding. I mean the upper front section of the tank
PostPosted: Sun Feb 15, 2009 4:57 pm
I guess he made those two bolt to reduce the steering, so that the fork can't hit the tank.
PostPosted: Sun Feb 15, 2009 9:30 pm
PostPosted: Mon Feb 16, 2009 1:20 pm
Hi Johanv.
Did you just bore a hole in the swing arm for the rear brake torq arm bracket and put a bolt thrue or? I am trying to solve this isue.
PostPosted: Mon Feb 16, 2009 1:55 pm
I drilled a small hole on the innerside of the swingarm (10mm) and a large (14?mm) hole on the outside of the swingarm. I made a bushing (inner diameter 10, outer 14? length?) and placed the bolt through it. I made a little drawing, the funny looking thing is the bolt :) Hope you understand the drawing, I have a better pic with measurements at home, i will place it here. tonight(GMT+1)
edit:
I used this:
PostPosted: Mon Feb 16, 2009 6:03 pm
PostPosted: Mon Feb 16, 2009 6:21 pm
My fork has a diameter of 53mm. Without the use of the steering stops, my forks will touch the tank at about 46 degrees. So I adjusted them to stop at about 45 degrees.
PostPosted: Mon Feb 16, 2009 6:27 pm
how many degrees is normall full steering ?
If I had adjusted my stop screws I would have lost quite a bit of steering range. Maybe not so important for riding, but more for maneuvering the bike.
PostPosted: Mon Feb 16, 2009 7:29 pm
Hi
So when you assemble, you tighten with a standard M10 nut on the other side (tyre side)?
Regards
Klaus
PostPosted: Mon Feb 16, 2009 7:35 pm
yes. I think i used m10X 50. And I used loctite to lock the bolt
PostPosted: Wed Jun 24, 2009 8:53 am
Hello everybody!!!
You have tried to drive the motorbike with your new fork!!??
I like very much your new-custom-paso and new fork!!!
I am thinking also myself to do this customize with 916 forks!
:thumbup:
zacchello
PostPosted: Sat Aug 08, 2009 3:22 pm
Yes I rode the bike with the new forks. It rides very good. But actually, the forks should be a little longer (+-3cm).
Some new pics:
