ducatipaso.org :: View topic - My PASO got new 17 " shoes
ducatipaso.org
http://ducatipaso.org/forum/
http://ducatipaso.org/forum/viewtopic.php?f=1&t=3616
Page 1 of 2
Author:  nilaus [ Fri Sep 18, 2009 8:09 pm ]
Post subject:  My PASO got new 17 " shoes
I am pretty pleased with the result. I only need a new chain to fit the bigger rear toothed sprocket. More pictures will be added for the end result.
Author:  Texas Red 88 [ Sat Sep 19, 2009 2:17 am ]
Post subject:  Re: My PASO got new 17 " shoes
What wheel package did you use? Looks like the stock swingarm.
Author:  nilaus [ Sat Sep 19, 2009 4:05 am ]
Wheels are from a 600 ss with a 17 mm shaft, front and rear. It was not possible to use the old shaft, because of there are no bearings there will fit in the wheel Ø 40 mm with a 20 mm haft, so I used the ss 17 mm shaft and got made a pair of new excentrics http://www.bikepics.com/pictures/1233491/ .
Author:  ducapaso [ Sat Sep 19, 2009 7:04 am ]
You'll need to raise the front mudguard 1/4"
No more than this or it will grind on the side panels! :,(
Author:  paso750 [ Sat Sep 19, 2009 8:06 am ]
Author:  nilaus [ Sat Sep 19, 2009 9:54 am ]
Machining the hub I also thought of doing, but you need the holes to align neatly. I think this was the best solution by making new eccentrics. If you want to reuse the pin for the caliper bracket, you will have to make a new bracket. I just drilled a hole in the swing arm, inserted a metal tube and a bolt for the pin, and used a bracket from a ss.
Author:  nilaus [ Mon Oct 05, 2009 8:59 pm ]
Fairing mounted. Nice ride and pleased with the looks :beer:
Before:
After:
Author:  higgy [ Mon Oct 05, 2009 9:22 pm ]
Very nice,looks a little stuffed up front :o
Author:  nilaus [ Mon Oct 05, 2009 9:41 pm ]
:D Jep, there's not much room , but no contact :)
Author:  Ken@Murayama-Paso [ Fri Oct 16, 2009 1:27 am ]
Does it use a normal speed meter?
I got new 17 " shoes converted from 400SS to my paso750 recently.
http://ameblo.jp/ducati750/entry-10353122117.html
But I have a problem with speed meter. A large margin of error came to occur as 100km/h indication at the time of 80km/h.
The speed meter is for normal 750paso. The speed meter gear is for 17 " 400SS(I think it's same one as 600SS).
How did you do it?
Author:  ducapaso [ Fri Oct 16, 2009 5:30 am ]
Author:  Ken@Murayama-Paso [ Fri Oct 16, 2009 5:50 am ]
Author:  ducinthebay [ Sat Oct 17, 2009 4:06 am ]
so, how would you describe the difference between the 16" and the 17"? Is low speed better, or worse? Is it different at high speeds? How is it in corners compared to what you had before? Besides the obvious fact that you now have brand new stick tires.
Phil
Author:  Finnpaso [ Sat Oct 17, 2009 4:24 pm ]
Nilaus, can you make some new mail with links and all details about Your 17" conversion, as here are many guys, who are intrested of such.... I visited your web page and there was good drawing about rear axle adjuster, but unfortunately my printer didnt show so clearly those measurements(mm) Very good job from You! :beer:
What You think about front braking now? I changed to 4 piston Brembos in my 750 Paso and it was amazing that difference to old 2 piston system, ....never back to 2 piston calipers anymore!.... :smoke: Have You drawing about adapters? How about front axle? Bearings? Chain line(offfset)? any problems? all is welcome surely... :beer:
Author:  Ken@Murayama-Paso [ Tue Oct 20, 2009 5:25 am ]
Page 1 of 2 All times are UTC
http://www.phpbb.com/
