ducatipaso.org • View topic - Yamaha Headlight conversion
It is currently Fri Oct 30, 2026 6:11 pm
 Post subject: Yamaha Headlight conversion
PostPosted: Fri Feb 26, 2010 12:37 pm
I bought the FZ headlight which was on ebay, now I was wondering if anyone had some hints for installing it.......... everything I found with search was rather old posts that really didn't explain well.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
 Post subject: Re: Yamaha Headlight conversion
PostPosted: Fri Feb 26, 2010 12:53 pm
viewtopic.php?f=3&t=3256
PostPosted: Fri Feb 26, 2010 2:06 pm
Reread again... I am not in europe and don't have the euro switch... I suppose ignore the switch mod., and ignore relay #3 and I should be good to go?
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Fri Feb 26, 2010 2:59 pm
what`s the difference between euro and US switch ? My switch has the small switch for Hi/Lo and the big one for OFF/Parking light/ON.
PostPosted: Fri Feb 26, 2010 3:06 pm
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Fri Feb 26, 2010 5:01 pm
Mike,
Witht he dual headlight version, I would take the time to install a relay to feed the power to it. What you would do, is run a direct lead (with a fuse in it) to the battery or starter solenoid (I prefer the solenoid) to fee the 2 lights direct and not thru the original harness. You then use the handlebar switch to manage the relay and tnot the full load.
Are you eletrically handy or will you need a drawing and such??
PostPosted: Fri Feb 26, 2010 5:08 pm
if you don`t have the ON/OFF switch you can do w/o relay 3, but you should run a yellow lead from the right headlight to relay 2 otherwise only hi beam will work on the right headlight.
PostPosted: Fri Feb 26, 2010 6:08 pm
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Sat Feb 27, 2010 3:15 am
Dual H4's without the relay will melt your ignition switch in short order(pun intended)
Take my word for it :,(
PostPosted: Sat Feb 27, 2010 2:06 pm
PostPosted: Sun Feb 28, 2010 10:27 am
Anyone have a pic of the fuse block end of the wiring..... not sure if I am clear on that part and bike is 60 miles away.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Sun Feb 28, 2010 1:07 pm
When i did my dual headlight conversion I used shellboss wiring diagram but modified it a bit, instead of modifying the headlight switch i added an extra swich in the dashbord to be able to run dual or singel lowbeam.
By at 2010-02-28
