It is currently Fri Feb 27, 2026 8:22 pm
[ 5 posts ] |
| Author |
reginapete
Post subject: how do i improve my headlight output? Posted: Thu May 05, 2005 6:26 am |
| Top |
jcslocum
Post subject: Posted: Fri May 06, 2005 8:11 pm |
| paso grand pooh-bah |
Be careful with a higher wattage bulb (if you try it)with the standard wiring. With all things electric, there is no free lunch. A higher output bulb will pull more amps. This could melt down the already crappy wiring.
The FZ headlight shows up on ebay once is a while.
| Top |
Finnpaso
Post subject: Posted: Sat May 07, 2005 7:40 pm |
Joined: Mon Jul 26, 2004 12:00 am Posts: 3081 Location: Finland
Its truth, that 750 Paso have too small electric wires(what is not so big problem anymore in 907IE..) but 907Ie injection system takes so much current from 350 W charging system, that cant use much bigger pulbs, what can be done easily in 750 Paso, if You have make those relay modificatios, what "need to do", if You want better working 750 Paso!!! I am very happy to my 750 Paso electrics, cause i have added 4 relays to her.....
Finnpaso
907IE
750Paso
| Top |
redpaso
Post subject: Posted: Sun May 08, 2005 11:58 pm |
Joined: Sun Feb 20, 2005 12:00 am Posts: 654 Location: Land of OZ (traylia that is) Troy Bayliss Country
_________________ Redpaso "My favourite peice of Ballet is a long sweeping corner"
| Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 19 guests |
