ducatipaso.org • View topic - how do i improve my headlight output?
It is currently Sat Feb 28, 2026 6:10 pm
 Post subject: how do i improve my headlight output?
PostPosted: Thu May 05, 2005 6:26 am
PostPosted: Thu May 05, 2005 8:24 am
PostPosted: Fri May 06, 2005 8:11 pm
Be careful with a higher wattage bulb (if you try it)with the standard wiring. With all things electric, there is no free lunch. A higher output bulb will pull more amps. This could melt down the already crappy wiring.
The FZ headlight shows up on ebay once is a while.
PostPosted: Sat May 07, 2005 7:40 pm
Its truth, that 750 Paso have too small electric wires(what is not so big problem anymore in 907IE..) but 907Ie injection system takes so much current from 350 W charging system, that cant use much bigger pulbs, what can be done easily in 750 Paso, if You have make those relay modificatios, what "need to do", if You want better working 750 Paso!!! I am very happy to my 750 Paso electrics, cause i have added 4 relays to her.....
907IE
750Paso
PostPosted: Sun May 08, 2005 11:58 pm
Redpaso
Users browsing this forum: No registered users and 35 guests
