BUB Exhaust ???? http://ducatipaso.org/forum/viewtopic.php?f=1&t=3740 |
Author: | ducinthebay [ Thu Nov 19, 2009 6:18 am ] |
Post subject: | BUB Exhaust ???? |
I have a set of BUB exhaust pipes for my 750 Sport project. I am trying to take out the baffles to repack them. Has anyone else ever taken these apart? There is a rivet in the back that I drilled out, but getting the core out is proving difficult. I have tried several bearing pullers, but I just can't get enough purchase on the inside of the core to get it loose. Any insight is appreciated. Cheers, |
Author: | higgy [ Thu Nov 19, 2009 10:59 am ] |
Post subject: | Re: BUB Exhaust ???? |
Most after market exhaust will have a length of the baffle that fits tightly at the front. A little heat from either propane or mapp without oxy will usually be enough to allow the baffle to slip out. Also most of the baffles I have run across have more than one rivet. Others the can comes off and the baffle is part of the header system. I have never taken a bub system apart so your mileage may vary ![]() |
Author: | Tamburinifan [ Thu Nov 19, 2009 1:47 pm ] |
Never seen a Bub system so pics would be nice! |
Author: | paso750 [ Thu Nov 19, 2009 2:58 pm ] |
viewtopic.php?f=9&t=2879 |
Author: | ducinthebay [ Thu Nov 19, 2009 5:07 pm ] |
Yup, mine look just like that, scratches and all, except mine are flat black. They have a reverse cone on the end that they welded to a baffle core. The whole bit is (as best I can tell) slipped into the end of the pipe and one pop rivet holds it in. I tried the heat already. Maybe I'll try more. Surely can't ruin the finish of flat black rattle can. I sprayed on some penetrating oil, so maybe that will work its magic in a few days. I also rapped on it with a hammer all the way around to loosten things up. I'm using an expanding core bearing puller with a slide hammer, but the core just doesn't get enough purchase and keeps slipping out. I need to make a better puller bit I think. Currently, BUB makes pipes mostly for Harleys and other cruisers. A California company that sponsored the land speed record bike the past few years. They made pipes for the Paso, and apparently the Sport. The Sport pipes are just a bit shorter than the Paso pipes, as the Paso headers are shorter than the Sports. Cheers, |
Author: | Fraser [ Thu Nov 19, 2009 7:20 pm ] |
Ducinthebay, Have not been inside a Bub muffler, but they are all different and never as you imagine. Here are some photos of inside a Suzuki GX1400 muffler that I stripped out for a wee project that I'm working on. The end cap looked like it was held on by 6 rivets, this was just to fool you. Tried opening it up with a plazma cutter, that didn't work, so cut the last 100mm off the end with a tungstin blade in a drop saw. Inside was a huge baffle, a thick lining and the whole thing was very heavy. Once all the crap was removed it worked a treat, light and sufficiently noisey. Fraser. |
Author: | englishstiv [ Thu Nov 19, 2009 10:47 pm ] |
I know when I cut down my Monster exhaust the front of the baffle had been tack welded in situ and no amount of heat woulld seperate it in the end I ground it through and then re welded I wonder if yours may of had a similiar build set up if all else fails run a grinder around the front seam and see it that loosens it, if it is in matt black already you can re weld and re paint good as new. |
Author: | paso750 [ Fri Nov 20, 2009 7:31 am ] |
pls. don`t post pics bigger than 1024x768. thx. G. |
Author: | englishstiv [ Fri Nov 20, 2009 9:25 am ] |
soz don't know why it has done that? It's from my usual photobucket site, have deleted it now. |
Author: | paso750 [ Sat Nov 21, 2009 8:43 am ] |
you didn“t have to delete it immedeately ![]() G. |
Author: | higgy [ Sat Nov 21, 2009 12:59 pm ] |
I have had issues with photobucket as well from time to time with photo sizing...fyi ![]() |
