| Oil cooling and motor temperature http://ducatipaso.org/forum/viewtopic.php?f=1&t=38 |
| Author: | Christian [ Mon Aug 09, 2004 5:58 am ] |
| Post subject: | Oil cooling and motor temperature |
The temperature level is very long time to increase up to 50°C. Depending on the ambiant temperature, the level coms never up to 50°C. it's not enough for a right using motor. Do you have experience ? What's the solution ? The oil must cross the radiators to garanty a good lubrification or is it possible to stop the oil before radiator with a termostat ? Thanks for help Christian |
| Author: | v2block [ Fri Aug 13, 2004 3:58 pm ] |
| Post subject: | |
helo christian, i would stop the airflow in the radiators .close them with a strong tape like duc-tape or similar. but keep an eye onthe temp.. |
| Author: | lceriani [ Mon Aug 16, 2004 9:56 pm ] |
| Post subject: | |
50°C seems too low... I usually go up to 80-100°C on summer. Is the temperature sensor ok? Are the connector oxidated? LC |
| Author: | ducapaso [ Sat Dec 25, 2004 9:52 pm ] |
| Post subject: | |
I have your same trouble on my dukess... The engine is running good, however I'm in order to ceck the valve located between the pump and the oil filter... I suppose it should bypass the oil flow straight to the engine in case of troubles in the coolers.... I think I'll clean the coolers inside too, so I'll be able to tell you something about. Have a nice ride, Ducapaso |
