| Displacement bump http://ducatipaso.org/forum/viewtopic.php?f=1&t=3805 |
| Author: | jklnhyde [ Fri Dec 18, 2009 9:12 pm ] |
| Post subject: | Displacement bump |
Has anyone bored or stroked their 750? What would be the easiest and least expensive route to more cc's and HP? Are there any specific guidelines to follow when overboring a Ducati cylinder or case? Rick |
| Author: | ducinthebay [ Sat Dec 19, 2009 12:51 am ] |
| Post subject: | Re: Displacement bump |
In general, the 750 engine is not a great candidate for hop-up ugrades. You can add some Hi compression pistons, cams, and improve the carbs and exhaust, and lighten up the internals with smaller flywheels and drilling holes in gears. With all that, it will run with a stock 900. But after that, its just very difficult to get much out of it. For a more complete and technical write up, see: http://www.bikeboy.org/performance.html#2v The biggest limitation to the 750 motor is the heads and the flow. I looked at putting on some 800 heads, which have big valves like the 900, and the same bolt pattern as the 750, but the dome is deeper and new pistons would have to be sourced, that may not be made. I'll sell you the heads if you are interested. The easiest and fastest way is to simply put a 900 motor into your 750. Larger displacement, larger valves, better selection of cams, and you can get a true 100hp if you spend enough money in upgrades. If you keep an open eye, you can pick up a good used 900 motor for less than $500, which is pretty cheap hop-up for 15hp. Heck, hi-comp pistons alone are $500. The 750 Sport is really easy to upgrade, as a 900 motor will drop right into the frame, and you simply use a later model SS swingarm, and your done. The Paso swingarm arrangement is a different story. I have no idea what it would take to adapt a 900 motor to a Paso. Cheers, |
| Author: | ducapaso [ Sat Dec 19, 2009 9:26 am ] |
I found a big bore kit for paso some time ago but i'm no more able to find it. It was a780 tuning kit from an italian factory |
| Author: | 21783mike [ Sun Dec 20, 2009 6:04 am ] |
Try Ed Milch He's been known to squeeze a bit more out - |
| Author: | higgy [ Sun Dec 20, 2009 12:04 pm ] |
Now available: 82mm/88mm/90mm Wiseco High Compression (13:1) Racing Pistons for 2 valve Ducati 650's and 750's . These forged racing pistons will increase both your torque and horsepower by ~10% compared to stock pistons. 82mm/88mm sets are drop-in and require no rebalancing of your crankshaft. 90mm pistons require additional work. These pistons require 110 octane racing fuel and are for closed course competition only. Price is $350 per set of two. Rings, wrist pins and clips are included. To order, please contact: ed@bimotacagiva.com Ed Milich Bimotacagiva.com PO Box 5 Torrance CA 90507 |
| Author: | jklnhyde [ Mon Dec 21, 2009 9:53 pm ] |
Okay, all good advise, but what about the 906/907 models? They were bored/stroked versions of the Paso 750, a sure drop-in for a carbureted 750/906 swap. Is this not a good swap? Would I get more satisfaction out of a bore job? I'm not looking for all-out HP, but I do have a garage full of 100+HP motorcycles and would like the Paso to have a bit more go. I do like the simplicity of a 88mm piston upgrade, but I'm not so sure of the availability of 110 octane fuel when I need it... Rick |
