| '91 to '97 ignition switch http://ducatipaso.org/forum/viewtopic.php?f=1&t=3816 |
| Author: | fredskidoo [ Fri Dec 25, 2009 12:20 am ] |
| Post subject: | '91 to '97 ignition switch |
I've found a 91-97 Supersport / Superbike / Monster / ignition switch and I'd like to know if I can use it to replace my 750's switch. I don't have a problem splicing wires and all. I just want to know if there are any unforeseen issues I need to know about. Thanks all . . . Ethan |
| Author: | ducinthebay [ Fri Dec 25, 2009 4:49 am ] |
| Post subject: | Re: '91 to '97 ignition switch |
Ethan, Many vintages of those switches have the same connector that was used on the Paso. If it looks the same, then it should fit. the mounting bolts are a bit different, but that can be overcome with a rattail file. Cheers, |
