ducatipaso.org • View topic - Factory Performance Upgrades
It is currently Fri Oct 30, 2026 3:02 pm
 Post subject: Factory Performance Upgrades
PostPosted: Mon Mar 15, 2010 5:24 pm
Hi to all,
Thanks for the insights, how can I identify if I have the factory performance upgrades on my bike?
Thanks, Vince
1988 Ducati Paso Desmo Limited in a pearl white
 Post subject: Re: Factory Performance Upgrades
PostPosted: Tue Mar 16, 2010 12:29 am
first step would be the numbers stamped into the mufflers, next would be what carb/s you have
PostPosted: Tue Mar 16, 2010 9:13 am
Uprating kit consisted of.... 1 040 horizontal pipe - 0370.84.023, 1 040 Vertical pipe - 0370.84.033, RH muffler 573 1 003 1A, LH muffler 574 1 003 1A, 36 degree advance flywheel 0370.46.470, 2 main jets, 2 air corrector jets, and a new gasket for the flywheel side cover.
That kit was a later release... August of 1988 and was dealer installed.
You will know if you have the mufflers as the outlet is quite a bit bigger than the stock ones.
If you mean the few factory equipped ones that were brought in for AMA homg. rules well that's a different story that is a bit fuzzy. Best I can tell they were all Red there were 50 labeled as limited, but maybe only 25 or less really were, the rest were just the stickers. Of those that were the real thing it's a bit of a mystery as to what was really done internally to them from the factory.... higher compression, bigger valves, heads ported and polished? I've heard different versions but nothing ever definitive....
I do have a set of heads on the shelf in the garage sitting in a box that may have came off of one of those but have not ever gotten around to taking any measurements but the valves do appear to be bigger on them.
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Tue Mar 16, 2010 10:18 am
I know of at least one that was white with red accents,headwork,exhaust and Dels, No one seems to know when the dels got installed but they came in a Ducati box with the mufflers and pipes
PostPosted: Tue Mar 16, 2010 10:56 am
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
PostPosted: Wed Mar 17, 2010 8:04 am
PostPosted: Sun Mar 21, 2010 11:42 pm
I definitely have the exhaust system, per your supplied part numbers! Thanks! :D
Assuming that I have the performance upgrades, what is the difference in hp vs the stock model?
Thanks to all, Vince
PostPosted: Mon Mar 22, 2010 6:09 pm
Nobody can tell about it, I guess....
PostPosted: Tue Mar 23, 2010 1:47 pm
Mike B.
08 HYM 1100S
06 800SS
89 KLR650
87 750 Paso LTD
64 125 Bronco
Users browsing this forum: Google [Bot] and 6 guests
