| Starting to look as it should http://ducatipaso.org/forum/viewtopic.php?f=1&t=3999 |
| Author: | 21783mike [ Fri Apr 02, 2010 4:08 pm ] |
| Post subject: | Starting to look as it should |
Please excuse the crappy cellphone pic |
| Author: | 21783mike [ Fri Apr 02, 2010 4:10 pm ] |
| Post subject: | Re: Starting to look as it should |
| Author: | 21783mike [ Fri Apr 02, 2010 4:12 pm ] |
| Author: | 21783mike [ Fri Apr 02, 2010 4:14 pm ] |
| Author: | englishstiv [ Fri Apr 02, 2010 4:31 pm ] |
Is it just me or is there no Picture??? Maybe try again Mike if I'm not the only one? I'm sure it looks nice |
| Author: | 21783mike [ Fri Apr 02, 2010 5:06 pm ] |
| Author: | Mc tool [ Sat Apr 03, 2010 1:25 am ] |
| Author: | 21783mike [ Sat Apr 03, 2010 9:00 am ] |
Lots of little things to do yet.... trim the rear fender to make it straight, remove turn signals since the euro light is installed, install lift handle and center stand.... and lots of cleaning of the frame and exhaust system might even remove the stickers and polish the cans... Painter has to touch up a few edges before it comes home and with DABR at the end of the month I'm going to be pushing it to have it ready on time. |
| Author: | 21783mike [ Mon Apr 12, 2010 2:35 pm ] |
Update went down to shop on sunday and hooked up last of wiring. Made a bit of additional chain clearance for rear 180/60 by taking about 1mm of spare rubber off the tire with a grinder Like a New bike.Only issue left is it's charging is very weak, so we will put in the spare stator I have tomorrow and hopefully she will be done. Mods.... Shinko 747 180/60/16 Rear, Podium 130/70/16 Front FZ Headlight w/silverstar bulbs, Euro Tail light All wiring now redone with relays Mikuni Carbs, Vacuum actuated petcock |
| Author: | randtcastell [ Mon Apr 12, 2010 4:24 pm ] |
congratulations! she's gorgeous. -randy. |
| Author: | jcslocum [ Mon Apr 12, 2010 8:11 pm ] |
Charging should be good once rewired. Did you clean all of the various grounds including the one at the back of the engine case? |
| Author: | 21783mike [ Tue Apr 13, 2010 1:12 am ] |
| Author: | persempre907 [ Sat Apr 17, 2010 7:01 am ] |
I love that white limited Congratulations!!! Ciao |
