| 1988 Paso swingarm alloy http://ducatipaso.org/forum/viewtopic.php?f=1&t=4029 |
| Author: | Vince [ Thu Apr 22, 2010 2:57 pm ] |
| Post subject: | 1988 Paso swingarm alloy |
Hi to all, Does anyone know what alloy Ducati used on the swingarm? I am going to modify it to accept a larger tire. I will post results as I progress. Thanks, Vince |
| Author: | Mc tool [ Sun Apr 25, 2010 4:28 am ] |
| Post subject: | Re: 1988 Paso swingarm alloy |
Yeah , I'm pretty sure its an aluminium alloy There are ways to fit available tyres to your paso without chopping the swing arm, have a look at some of the recent posts . |
| Author: | ducinthebay [ Mon May 03, 2010 5:05 pm ] |
A very common aluminum alloy for extrusion is 6061. Other alloys can be extruded, but the range is rather small. I would have to assume that since the Paso was in small production numbers, and made as a production bike, that they chose a very common alloy. Here's a link: http://www.midstal.com/sft334/aluminum_ ... alloys.pdf I don't recall the common alloys for casting, but a websearch may give you the info you need. Cheers, |
