| what are these holes for ? http://ducatipaso.org/forum/viewtopic.php?f=1&t=4112 |
| Author: | paso750 [ Mon May 31, 2010 5:20 pm ] |
| Post subject: | what are these holes for ? |
My engine has 3 holes on the back. 2 small ones are on the height of the swingarm axle (I wonder if these are original) and there`s a big one on the bottom right. My friends Cagiva Elefant 900 engine doesn`t have any of these. G. |
| Author: | Tamburinifan [ Tue Jun 01, 2010 12:14 am ] |
| Post subject: | Re: what are these holes for ? |
Edit: Did not remember correctly.... |
| Author: | jcslocum [ Tue Jun 01, 2010 10:55 am ] |
Are there Allen screws in there?? |
| Author: | paso750 [ Tue Jun 01, 2010 11:22 am ] |
it looks like there would be. Meanwhile I can“t check anymore as the swingarm and shock are back in place. |
| Author: | micklm [ Tue Jun 01, 2010 2:25 pm ] |
Hi, For two of them I would guess someone has created threaded holes for grease points to the swingarm pivot? But I can't think what the third would be. I don't have them on any on the various two valve crankcases I have. Curious, Mick |
| Author: | whitepaso [ Wed Jun 02, 2010 1:41 pm ] |
I have them on my engine too. I assumed the two at the top were either for non-installed grease fittings or to clamp the swingarm axle for ?? reason. Have no clue on the bottom one. |
| Author: | paso750 [ Wed Jun 02, 2010 4:20 pm ] |
ok, that`s good to now. So they are probably original. Are yours open or is there a hex screw inside ? I was also thinking about grease fittings. G. |
| Author: | whitepaso [ Thu Jun 03, 2010 4:25 am ] |
I'm pretty sure they have hex screws in them. I have a photo of the engine while I had mine apart but the resolution is not good enough to tell for sure. |
| Author: | 21783mike [ Thu Jun 03, 2010 4:40 am ] |
I happened to look at my spare engine and it appears that there are roll pins in the 2 small holes.... the other large one not sure what it was intended for, maybe an oil line? |
