It is currently Wed Mar 11, 2026 9:50 am
[ 9 posts ] |
| Author |
Post subject: what are these holes for ? Posted: Mon May 31, 2010 5:20 pm |
| paso grand pooh-bah |
My engine has 3 holes on the back. 2 small ones are on the height of the swingarm axle (I wonder if these are original) and there`s a big one on the bottom right. My friends Cagiva Elefant 900 engine doesn`t have any of these.
| Top |
Post subject: Re: what are these holes for ? Posted: Tue Jun 01, 2010 12:14 am |
Joined: Thu Jun 21, 2007 12:00 am Posts: 1501 Location: Gothenburg, SWEDEN
Edit: Did not remember correctly....
_________________ Gert
907 I.E. -91 M900 -97 MTS 1100s -07
| Top |
jcslocum
Post subject: Re: what are these holes for ? Posted: Tue Jun 01, 2010 10:55 am |
Are there Allen screws in there??
| Top |
Post subject: Re: what are these holes for ? Posted: Tue Jun 01, 2010 11:22 am |
it looks like there would be. Meanwhile I can“t check anymore as the swingarm and shock are back in place.
| Top |
micklm
Post subject: Re: what are these holes for ? Posted: Tue Jun 01, 2010 2:25 pm |
Joined: Fri Jun 05, 2009 8:53 pm Posts: 103 Location: Taranaki, New Zealand
For two of them I would guess someone has created threaded holes for grease points to the swingarm pivot?
But I can't think what the third would be.
I don't have them on any on the various two valve crankcases I have.
Curious,
Mick
_________________ 906 Paso 1989 w/ 17in wheels
| Top |
whitepaso
Post subject: Re: what are these holes for ? Posted: Wed Jun 02, 2010 1:41 pm |
Joined: Sun Feb 19, 2006 12:00 am Posts: 143 Location: Bolivar, Ohio USA
I have them on my engine too. I assumed the two at the top were either for non-installed grease fittings or to clamp the swingarm axle for ?? reason. Have no clue on the bottom one.
| Top |
Post subject: Re: what are these holes for ? Posted: Wed Jun 02, 2010 4:20 pm |
ok, that`s good to now. So they are probably original. Are yours open or is there a hex screw inside ? I was also thinking about grease fittings.
| Top |
whitepaso
Post subject: Re: what are these holes for ? Posted: Thu Jun 03, 2010 4:25 am |
I'm pretty sure they have hex screws in them. I have a photo of the engine while I had mine apart but the resolution is not good enough to tell for sure.
| Top |
21783mike
Post subject: Re: what are these holes for ? Posted: Thu Jun 03, 2010 4:40 am |
Joined: Thu Aug 28, 2008 9:48 am Posts: 102 Location: Smithsburg, MD
I happened to look at my spare engine and it appears that there are roll pins in the 2 small holes.... the other large one not sure what it was intended for, maybe an oil line?
_________________ Mike B. 08 HYM 1100S 06 800SS 89 KLR650 87 750 Paso LTD 64 125 Bronco
| Top |
[ 9 posts ] |
Users browsing this forum: No registered users and 37 guests |
