It is currently Sat Jun 20, 2026 11:26 pm
[ 3 posts ] |
| Author |
88WhitePaso750
Post subject: Tire Size Question Posted: Fri Jun 04, 2010 8:04 pm |
Joined: Fri May 14, 2010 12:39 am Posts: 37 Location: USA
This is a little different question when compared to the usual "What tires will fit".
I would like to understand what exactly the numbers mean.
For Example 150/80 VB 16 (71V)
First off, I get the 150 width, 80 sidewall profile, V Rating and 16" rim, What I don't quite understand is the 71V. Can anyone shed some light on this often forgotten tire specification number?
Chris
_________________ 1978 Yamaha 650 Special 1987 Yamaha FZ600 1993 Suzuki GSX-R 1100 1995 Kawasaki Ninja 250R (wife's) 1988 Ducati Paso 750 2009 Yamaha FZ1
| Top |
Post subject: Re: Tire Size Question Posted: Fri Jun 04, 2010 9:26 pm |
| paso grand pooh-bah |
normally it should be 150/80B16 71V. 80 is the height of the tire as percentage of its width. A 150/80 should be 150mm wide and hence 120mm high. 71 is the weight index. 71 corresponds to 345kg max. load (with proper set tire pressure). Lower tire pressure will reduce max load. At speeds above speed index of the tire max load will decrease. B stands for bias belted, R would mean radial.
| Top |
88WhitePaso750
Post subject: Re: Tire Size Question Posted: Wed Jun 23, 2010 9:25 am |
Thanks for the info
| Top |
[ 3 posts ] |
Users browsing this forum: No registered users and 16 guests |
