| Busted Display Needs Replacing http://ducatipaso.org/forum/viewtopic.php?f=1&t=4156 |
| Author: | ColoradoPasoFan [ Sat Jun 19, 2010 6:31 pm ] |
| Post subject: | Busted Display Needs Replacing |
Hello all, The clips on my '87 750 Paso display became brittle and broke so now the clear cover comes off. I called the nice people at DucatiOmaha about getting a replacement, sadly those aren't available anymore; I have also checked with local dealers and junk yards but nobody has one either. I searched through the forums here and found a post in early 2007 from ducapiero about connecting the fuel indicator to an Acewell display. Unfortunately the photobucket pics are no longer good so I don't know what it looks like. I'm in the market for a new display, any suggestions on which would be good alternatives? ![]() Mark |
| Author: | persempre907 [ Sat Jun 19, 2010 7:25 pm ] |
| Post subject: | Re: Busted Display Needs Replacing |
It will be very hard to find a new dashboard screen. You'll find easier the whole dashboard which sometimes appears on ebay. Ciao |
| Author: | higgy [ Sat Jun 19, 2010 7:52 pm ] |
If the cover is basically in one piece just the clips are gone you can carefully reinstall it with some clear silicone sealer. Place a small bead low on the bezel then lower the cover onto it so that the excess rolls out on the bezel and not up into the cover. Let it dry for 24 hours and then trim off any excess Scratchs can be repaired with flame polishing...BE advised flame polishing takes lots of practice on some thing other than your hard to replace cover.
| Author: | Duc906 [ Sat Jun 19, 2010 11:44 pm ] |
Try Ian Gowanloch in Aust. http://myworld.ebay.com/italsparesducati/ He was selling complete dash units. |
| Author: | jayh [ Wed Jun 23, 2010 10:01 am ] |
Yep, Ian Gowanloch sold me a brand new one only several weeks ago,and fairly cheap too.Give him a try. Rgds. Jay. |
| Author: | higgy [ Wed Jun 23, 2010 12:15 pm ] |
In The US you can try Ed ducpower |
| Author: | Mc tool [ Tue Jun 29, 2010 1:31 am ] |
I made one from clear plastic ( I wanna say perspex but Im not sure what it was ) and ultraclear araldite , by shaping the main lense and then, by heating and bending, form a " rim " which I then glued on. A previous owner spilt brake fluid on the lense |
| Author: | ColoradoPasoFan [ Sat Sep 04, 2010 10:31 pm ] |
OK, so I used Guerilla Glue to fix the display, got it up and running for about 2 weeks before the key switch/ignition stopped working....GRRRR!!!! I placed an order with Ducati Omaha to buy a new one but it's been discontinued...again GRRRR!!!! Ebay and Craigs List have both turned up nothing so I e-mailed ducpower.com to see what they may have, wish me luck! |
| Author: | higgy [ Sat Sep 04, 2010 11:40 pm ] |
| Author: | paso750 [ Sun Sep 05, 2010 8:12 am ] |
you can try to fix it yourself. http://www.box.net/shared/4evp1px5be G. |
| Author: | persempre907 [ Tue Sep 14, 2010 9:28 pm ] |
| Author: | Mc tool [ Wed Sep 15, 2010 9:07 pm ] |
| Author: | higgy [ Thu Sep 16, 2010 12:01 am ] |
