ducatipaso.org :: View topic - airbox clips
ducatipaso.org
http://ducatipaso.org/forum/
airbox clips
http://ducatipaso.org/forum/viewtopic.php?f=1&t=4293
Author:  paso750 [ Mon Sep 06, 2010 10:54 am ]
Post subject:  airbox clips
Higgy,
if you still can get the clips from a Supersport airbox as you had mentioned lately, take them.
I knew I still had one or two somewhere (from an SS <96) so after finding them I removed the pin and tried to cut off a small part of the rolled in side with a multifunction rotary tool. That square wire is a little wider than the clip of the Paso so you have to grind off some material from the airbox lid but otherwise it works just fine.
Author:  higgy [ Mon Sep 06, 2010 9:48 pm ]
Post subject:  Re: airbox clips
Thanks G
I did :thumbup:
Page 1 of 1 All times are UTC
http://www.phpbb.com/
