ducatipaso.org • View topic - airbox clips
It is currently Thu Mar 12, 2026 12:44 pm
 Post subject: airbox clips
PostPosted: Mon Sep 06, 2010 10:54 am
Higgy,
if you still can get the clips from a Supersport airbox as you had mentioned lately, take them.
I knew I still had one or two somewhere (from an SS <96) so after finding them I removed the pin and tried to cut off a small part of the rolled in side with a multifunction rotary tool. That square wire is a little wider than the clip of the Paso so you have to grind off some material from the airbox lid but otherwise it works just fine.
 Post subject: Re: airbox clips
PostPosted: Mon Sep 06, 2010 9:48 pm
Thanks G
I did :thumbup:
Users browsing this forum: No registered users and 49 guests
