| Will 907ie rims fit on a Paso 750?? http://ducatipaso.org/forum/viewtopic.php?f=1&t=4588 |
Page 1 of 3 |
| Author: | 88WhitePaso750 [ Sat Feb 12, 2011 3:24 am ] |
| Post subject: | Will 907ie rims fit on a Paso 750?? |
Does anyone know if 907ie rims will fit on a Paso 750. I am interested in moving to 17" rims and I am trying to get ideas on how to source new rims. |
| Author: | paso750 [ Sat Feb 12, 2011 9:07 am ] |
| Post subject: | Re: Will 907ie rims fit on a Paso 750?? |
| Author: | nnnnnnorman [ Sat Feb 12, 2011 9:10 am ] |
thats a novel idea..... how come no one thought of that before??? |
| Author: | ducinthebay [ Mon Feb 14, 2011 5:04 am ] |
There is also the issue of the brakes. The 907 wheels are basically the same as the SS wheels and Monster wheels. Cheers, |
| Author: | 88WhitePaso750 [ Mon Feb 14, 2011 2:41 pm ] |
Thanks for the info everyone. So it looks like in order to do a swap to 17" wheels I would need to address the following: * Source the 17" wheels * Sort the bearing issues out * Raise the front mudguard * Lengthen the chain * Source rotors * Relocate calipers I was hoping to find a step by step complete conversion walk through with detailed part info and required modifications. I have searched here quite a few times and have never found a thread that I felt comfortable following. I am going to need new rubber this spring and was tring to decide between going with the Avon tires that Ducati Germany has recommended, or doing a permanent fix by moving to 17" wheels. Jury is still out. |
| Author: | ducinthebay [ Mon Feb 14, 2011 5:40 pm ] |
You don't have to change bearings on the front wheel, as the forks already accept the 17mm axle. |
| Author: | paso750 [ Mon Feb 14, 2011 5:41 pm ] |
But on the rear you have to. There`s some info in my download thread on top of this forum. For a 17" conversion there`re several parts you need to get made. G. |
| Author: | nnnnnnorman [ Mon Feb 14, 2011 6:38 pm ] |
in my opinion..... keep the 750 original as possible..... ie 16" inch wheels with more recent rubber.... then buy another ducati if you must have 17" wheels.
| Author: | 88WhitePaso750 [ Tue Feb 15, 2011 3:16 pm ] |
My investigation of 17" rims is not due to my desire to have 17" rims on a Paso. My investigation is to try and find a ongoing way to keep my Paso rolling. I am going to order up some recommended 16" tires. Thanks everyone for your comments. |
| Author: | persempre907 [ Tue Feb 15, 2011 5:42 pm ] |
| Author: | nnnnnnorman [ Tue Feb 15, 2011 7:45 pm ] |
yes. good choice. IMHO lets keep those paso that are left original that way.
| Author: | ducinthebay [ Wed Feb 16, 2011 12:00 am ] |
Always the debate when dealing with classic bikes. Should I upgrade and modify to keep it relatively current, Or do I keep the design intent and acknowledge the period that it was built? If its a lovely stock bike in the first, keep it stock. If the bike is already bastardized, keep going. Cheers, Phil |
| Author: | Mc tool [ Wed Feb 16, 2011 6:46 am ] |
| Author: | nnnnnnorman [ Wed Feb 16, 2011 7:37 am ] |
its true. if only we could get modern tyres to that design... the best of both worlds.
| Author: | persempre907 [ Sat Feb 19, 2011 11:56 am ] |
Really, the best thing I can tell you is that I have no more trouble with that damned Weber carb... Even if I also was caught by the 750 look... Ciao |
| Page 1 of 3 | All times are UTC |
