| Fork Seals http://ducatipaso.org/forum/viewtopic.php?f=1&t=4707 |
| Author: | socaljeff3798 [ Fri Apr 01, 2011 5:40 am ] |
| Post subject: | Fork Seals |
I need to replace the fork seals on my 750 Paso Does anyone know of a good source for these?....or like everything else on these bikes are they made from "Unobtainiam"? Thanks in advance, Jeff |
| Author: | paso750 [ Fri Apr 01, 2011 2:22 pm ] |
| Post subject: | Re: Fork Seals |
Jeff add your location to your profile. Assuming you are in Germany I could tell you where to find them but you`re probably not. The original ones are 41,7mm 55mm 10/10,5mm (inner diameter, outer diameter, height/height of seal lip). 41,7 55 8/10,5 works also fine. Go to any bike shop that sell parts, clothing etc with the dimensions and check if they have or can order them. Most shops don`t have a problem getting them. What parts of a Paso are unobtanium ? Other than the instrument cluster cover I couldn“t think of one. G. |
| Author: | Foxtee [ Fri Apr 01, 2011 9:53 pm ] |
Hi Jeff, just did the oil & dust seals on mine , got the oil seals of these guys http://cgi.ebay.com/Ducati-Paso-750-198 ... 43a1a3b64a they are also on trademe.co.nz . Got my dust seals from here http://www.ducati-gowanloch.com/catalog ... c5b78c6e62 Happy hunting
