It is currently Sat Oct 31, 2026 3:56 am
Page 1 of 1
[ 2 posts ] |
| Author |
Message |
aldo.agus
Post subject: 36 Dell'Orto PHF carbs single command Posted: Sun Apr 10, 2011 8:06 pm |
Joined: Mon Mar 24, 2008 4:44 pm Posts: 6 Location: Italy
year: 1986
Hello everyone! I want to install the 36 Dell'Orto PHF carbs single command (see photo) Does anyone know what kind of manifold I have to use? (Ducati Indiana? Cagiva Elefant? Good evening to all from Cagliari (Sardinia, Italy)
| Top |
Post subject: Re: 36 Dell'Orto PHF carbs single command Posted: Mon Apr 11, 2011 1:09 am |
| paso grand pooh-bah |
Joined: Sat Sep 03, 2005 12:00 am Posts: 1323 Location: SF Bay Area
There is no manifold set up that will let you keep them joined with one cable, that I know of. If you split them up, then you can use the Malossi manifolds, which are similar to the Pantah motors manifolds. The Mikuni carbs on later models are down draft, not side draft, so those manifolds won't work with those carbs. You may need to get new caps for each carb to remove the rocker assemlies. I think the slides should adapt just fine.
_________________ Duc in the Bay 1990 750 Sport x2-Rosso Blanko (900ss copy) & Nuovo Nudo (Scrambler project) 1991 907 -mostly stock 2002 ST4s - Lots of mods.
| Top |
Page 1 of 1
[ 2 posts ] |
Who is online |
Users browsing this forum: No registered users and 14 guests |
