| Tyre pressures http://ducatipaso.org/forum/viewtopic.php?f=1&t=4774 |
| Author: | Graemer57 [ Wed Apr 27, 2011 5:28 pm ] |
| Post subject: | Tyre pressures |
Any advice on what tyre pressures to run on 750 Paso. Am 16 stone 34 Front. 38 Rear ??? |
| Author: | paso750 [ Wed Apr 27, 2011 6:32 pm ] |
| Post subject: | Re: Tyre pressures |
normally I would just tell you to download the manual(s). But yes, it´s correct. Congratulations for the new bike. Hope it`s a good one. G. |
| Author: | higgy [ Wed Apr 27, 2011 7:36 pm ] |
+/- 2 psi Big guy |
| Author: | paso750 [ Wed Apr 27, 2011 7:40 pm ] |
yep, a bit more than recommended in the front seemed to make handling a little better with the old tires. |
| Author: | Duc750 [ Wed Apr 27, 2011 8:02 pm ] |
A few more PSI probably made the profile a bit taller.............. like the alternate size fitted to the blade !
| Author: | paso750 [ Wed Apr 27, 2011 8:13 pm ] |
not so much more ![]() 3psi are sufficiant. According to tire manufacturers and dealers I talked to in the past this is in limits that will not make much difference in wear. |
| Author: | Graemer57 [ Thu Apr 28, 2011 7:55 am ] |
Thanks for the advice. i had looked in the manual but asked because I wonted to tap into the experience of others who, like me, might not be as slender as they used to be :-) I run my R1200RT with slightly higher pressures as it handles much better that way, especially two up |
| Author: | higgy [ Thu Apr 28, 2011 11:15 am ] |
I'd be happy at 16 stone only another 3/7 to go from 20 a year ago
