| Clutch problem????? http://ducatipaso.org/forum/viewtopic.php?f=1&t=4788 |
| Author: | Vince [ Sun May 01, 2011 7:16 pm ] |
| Post subject: | Clutch problem????? |
Hi` I gotta a question for you guys I was on a nice little ride yesterday and the bike was running great but all of a sudden I noticed my gears were not working properly I had use force to get it in the next gear? Could any of you tell me might be the problem i took the main cover off to see if i had a bad bearing it looks decent |
| Author: | fredskidoo [ Sun May 01, 2011 7:37 pm ] |
| Post subject: | Re: Clutch problem????? |
If you feel that the clutch isn't engaging or dis-engaging correctly or consistently I suggest that you start with bleeding the fluid clutch system - in it's entirety . . . You will find a wealth of information and experiences involved with the Paso's "bleeding clutches" right here - dig in ![]() |
| Author: | jcslocum [ Mon May 02, 2011 11:16 am ] |
Fully flush the fuild with new as step #1. That should help if the fuuild was contaminated with water. Once hot that water boils out of the fluid and creates a problem disengaging thet gears fully. |
