| New to this forum! http://ducatipaso.org/forum/viewtopic.php?f=1&t=4822 |
| Author: | paso88 [ Wed May 18, 2011 7:20 pm ] |
| Post subject: | New to this forum! |
Just picked up an 88 Paso 750 with original road course mufflers still on it. was told the engine has been swapped form a 2000 Monster. Currently in the shop for a check up.....Not sure if it is a limted but from what I have read it might be. Question I have is, does the fuel pump always make a clicking sound when the key is turned on? Thanks in advance.....NEW to Ducati
| Author: | higgy [ Wed May 18, 2011 9:53 pm ] |
| Post subject: | Re: New to this forum! |
I would not call it a click,but for sure there is a distinctive sound |
| Author: | paso88 [ Wed May 18, 2011 11:03 pm ] |
Thanks for the reply Higgy! It is in the shop now and I told my mechanic about that noise....wasn't sure if it was normal or not. From your reply I guess it is normal to hear that from now on.............. |
| Author: | Fraser [ Thu May 19, 2011 3:55 am ] |
Paso88, It might sound more like "ticking", as in a giant bomb, counting down, starting fast then slowing down. You will get to know it well. Welcome to the world of Ducati. Cheers, Fraser. |
| Author: | higgy [ Thu May 19, 2011 7:50 am ] |
yes,sort of like wind up clock backwards if that makes sense ![]() last 2 to 3 seconds getting quieter as the pressure increases. I think if I have time later today I can make a recording of it if that would help the 750 the 906 and the 907 each have the sound just slightly different for each model
| Author: | paso88 [ Thu May 19, 2011 12:49 pm ] |
Thanks guys, I appreciate the input on this matter. Time to call my mechanic and tell him that it is normal for it to tick away........thought at first it was a spark plug firing on its own without the engine running. That's what it sounded like till I pulled off the left side fairing and put my ear to the iline fuel pump. Weird man.....just weird! Thanks again!!!!!! |
| Author: | persempre907 [ Thu May 26, 2011 7:59 pm ] |
Welcome on the forum and on the oddest sounds you've ever heard .Ciao
| Author: | Antzo [ Fri May 27, 2011 11:27 am ] |
Welcome! as long as you hear the tick tick tick all is well , if you don't hear it then start to worry
| Author: | streetsurfer [ Fri May 27, 2011 1:31 pm ] |
What you're hearing is the "key on" reminder. Ahead of it's time for an 88 bike wouldn't you say? |
