ducatipaso.org • View topic - Weber Question- Float needle
It is currently Sun Jun 21, 2026 7:22 pm
 Post subject: Weber Question- Float needle
PostPosted: Wed Jun 29, 2011 6:18 pm
Having stripped down the carb I'm having difficulties removing the float needle, it unscrews ok but hits the float bracket , it looks like the thin float shaft is pinched into the housing on one side, does it need to be forced open to remove the shaft?
88 750 Paso Limited
87 750 Paso Rosso
90 851 SuperBike - converting to AHRMA racebike!
93 888SPO Bella
 Post subject: Re: Weber Question- Float needle
PostPosted: Wed Jun 29, 2011 7:08 pm
I used a thin nail and a rubber hammer to push out the floater axle. If you push it out a bit you can grab it with some pliers and remove it and the floater.
PostPosted: Wed Jun 29, 2011 7:20 pm
Thanks I thought I would have to be a little brutal with it but wanted expert advice!
88 750 Paso Limited
87 750 Paso Rosso
93 888SPO Bella
PostPosted: Wed Jun 29, 2011 11:01 pm
also,it only comes out from one end,motion is from the solid end to the spit end, If you do it backwards you will need a new carb top,assuming you can find one so do pay attention :banghead:
PostPosted: Thu Jun 30, 2011 2:41 am
Well thanks for the advice and I followed it closely however right at the last gentle tap the housing broke off on the split side :banghead: :banghead: :banghead: :banghead: :banghead:
Ok plan B, I have a complete 96 900SS carb setup what do I need to do exactly for this conversion to work? I have a 900ss airbox but no Paso airbox as the weber came with a K&N air filter. I know the SS won't fit but what alternatives do I have and do I need to rejet?
88 750 Paso Limited
87 750 Paso Rosso
93 888SPO Bella
PostPosted: Thu Jun 30, 2011 9:21 am
oh no, sorry to hear that. On which side did you tap ? The split side holds the point of the axle so that is where you should have tapped with a nail. It says in the Weber manual "Always remove pin through solid boss not split one". Should`ve mentioned that. :(
The SS airbox won`t fit into the frame so you would have to use filter pods or modify a Paso airbox. What you need is described in the FAQs. I.e. accellerator grip + cables, carb manifolds from a 750 SS or Monster. The ones from a 900 will work, too if you don`t use an airbox as they are longer so the carb will stand slightly twisted. You can try the carbs jetting. The one of the 750 is a little different but at the end the jetting will depend on your airfilter setup, exhaust etc.
PostPosted: Thu Jun 30, 2011 2:00 pm
Thanks but I went the other way with the nail.. :,(
I see that the manifolds are indeed longer from the 900ss, so if I use those carbs what type of airfiler works best if no airbox can be used? just a regular K&N
I also have the Bollenbach 750 that I bought earlier in the year, I need to look at that setup...maybe today
88 750 Paso Limited
87 750 Paso Rosso
93 888SPO Bella
PostPosted: Thu Jun 30, 2011 9:00 pm
Corse,
Uni Filter do some great aftermarket filters/pods to suit the SS carbs.
http://www.unifilter.com/online%20catal ... ucati.html
That's what I use, they are good.
Fraser.
750 Paso
1980 Moto Morini 500 Sport
2013 Yamaha MT-01
PostPosted: Thu Jun 30, 2011 11:28 pm
It is always best to support the holder with a block of wood,or learn to cuss in Italian.....guess I should have mentioned that,but then again it does not take a lot of force to change it live and learn ducatista :banghead:
PostPosted: Fri Jul 01, 2011 8:14 am
PostPosted: Sat Jul 02, 2011 3:26 am
I was gentle with it too and took the advice to go that way! oh well its a good excuse to dump the weber anyway...
I noticed my Bollenback is fitted with 38 FCRs I have not ridden it yet and wonder how much better it will be?
88 750 Paso Limited
87 750 Paso Rosso
93 888SPO Bella
