| Will another 750 or Larger motor fit the 750 paso frame? http://ducatipaso.org/forum/viewtopic.php?f=1&t=496 |
Page 1 of 2 |
| Author: | Theo [ Tue Jul 05, 2005 6:13 pm ] |
| Post subject: | Will another 750 or Larger motor fit the 750 paso frame? |
| Author: | Skins [ Tue Jul 05, 2005 7:56 pm ] |
| Post subject: | |
| Author: | redpaso [ Wed Jul 06, 2005 12:37 am ] |
| Post subject: | |
| Author: | mike [ Wed Jul 06, 2005 12:44 am ] |
| Post subject: | |
| Author: | Theo [ Wed Jul 06, 2005 1:13 am ] |
| Post subject: | |
| Author: | DesmoDog [ Wed Jul 06, 2005 3:34 am ] |
| Post subject: | |
| Author: | redpaso [ Wed Jul 06, 2005 5:03 am ] |
| Post subject: | |
| Author: | lceriani [ Wed Jul 06, 2005 1:07 pm ] |
| Post subject: | |
Hallo, I have a M900 '95 engine running in my Paso 750 frame, with a pair of Mikuni BDST38 and K&N air filters. Well... it works but with some little problems: since Paso mounts 160/60 R16 tyres while Monster uses 170/60 R17, the sprocket is not aligned with the crown and the chain works bad. It maybe a minor problem for most, but for me it causes a bad accident when the crown decided it was all too much and detached from the wheel, breaking the chain at 140 Km/h.... LC |
| Author: | Skins [ Wed Jul 06, 2005 5:08 pm ] |
| Post subject: | |
Oh dear ... that's bad news, Luca. Did that happen recently? |
| Author: | lceriani [ Wed Jul 06, 2005 5:38 pm ] |
| Post subject: | |
It happened on August 2002, during a "hard ride" in val trebbia... (I posted a message about it on the previous version of ducatipaso.org forum) The crown bolts broke and the crown detached from the wheel, then the chain broke itself and crushed into the engine, causing everything to mess up. Here is a picture about the damage... I contacted some local Ducati service, buth they all refused to repair the damage (at least at a reasonable cost) because the repair cost would have been much more than the value of the Paso... then it started my adventure as a mechanic on my Duke! It was an hard work, but now the bike is (almost) on the road. LC |
| Author: | Skins [ Wed Jul 06, 2005 5:57 pm ] |
| Post subject: | |
What motor do you have in it now? |
| Author: | lceriani [ Wed Jul 06, 2005 6:10 pm ] |
| Post subject: | |
The accident happened with the M900 engine already mounted, probably because of the bad sprocket-crown aligment. Finally I decided to keep the same engine, revised and soldered! LC |
| Author: | Skins [ Wed Jul 06, 2005 6:58 pm ] |
| Post subject: | |
I hope you have the chain aligned properly now! |
| Author: | redpaso [ Wed Jul 06, 2005 11:46 pm ] |
| Post subject: | |
| Author: | Theo [ Thu Jul 07, 2005 12:51 am ] |
| Post subject: | |
