| ECU availability http://ducatipaso.org/forum/viewtopic.php?f=1&t=4960 |
Page 1 of 2 |
| Author: | thack [ Fri Jul 22, 2011 1:06 am ] |
| Post subject: | ECU availability |
I have a chance to buy about 1/2 of a Paso 750. The engine/frame/swingarm and rear wheel. No electronics come with the bike. How hard is it to find an ECU? Can I just wait it out on eBay? Mike |
| Author: | Desmo_Demon [ Fri Jul 22, 2011 3:29 am ] |
| Post subject: | Re: ECU availability |
| Author: | Turin [ Fri Jul 22, 2011 7:42 am ] |
Check here. He's also Guzzitech on E-bay |
| Author: | paso750 [ Fri Jul 22, 2011 7:49 am ] |
what do the ECU connectors look like ? If there are 2 it`s a Kokusan, it`s only one it`s a Digiplex. And pls. add your location to your profile, thx. G. |
| Author: | angelix [ Fri Jul 22, 2011 8:38 am ] |
| Author: | paso750 [ Fri Jul 22, 2011 9:57 am ] |
| Author: | angelix [ Fri Jul 22, 2011 11:24 am ] |
| Author: | Desmo_Demon [ Fri Jul 22, 2011 6:31 pm ] |
| Author: | thack [ Fri Jul 22, 2011 11:25 pm ] |
The only electronics it has are what is bolted to the motor. No harness, no module. It does have the coils. I've since found a module on ebay and harneses are available there too. Thanks for the wealth of information. I'm going to go get it. I can't go wrong with the wealth of knowledge here! Mike Houston, Tx |
| Author: | thack [ Fri Jul 22, 2011 11:51 pm ] |
| Author: | angelix [ Sat Jul 23, 2011 12:23 am ] |
| Author: | paso750 [ Sat Jul 23, 2011 8:48 am ] |
| Author: | paso750 [ Sat Jul 23, 2011 3:37 pm ] |
angelix do you have the maps from the Pederzini modules and if so from which ones ? G. |
| Author: | angelix [ Sat Jul 23, 2011 8:17 pm ] |
| Author: | Tamburinifan [ Sun Jul 31, 2011 10:15 pm ] |
On bikes w Kokusan from factory the idle advance is marked on the flywheel, if that helps... |
