ducatipaso.org • View topic - fuel valve 750 paso
It is currently Sun Sep 28, 2025 1:58 pm
 Post subject: fuel valve 750 paso
PostPosted: Sun Aug 07, 2011 5:44 pm
Hello all I am looking for a gas tank fuel valve for my 1988 paso if anyone knows where I can get the correct one please help. I also need a rebuild kit for my carburetor it is a 44 DCNF any and all help would be appreciated. :banghead: :banghead: :banghead:
 Post subject: Re: fuel valve 750 paso
PostPosted: Sun Aug 07, 2011 10:59 pm
Do you mean the fuel petcock?
PostPosted: Sun Aug 07, 2011 11:28 pm
Yes sorry for the confusion.
PostPosted: Mon Aug 08, 2011 10:08 am
it may help if you`d add to your profile where you`re located.
PostPosted: Mon Aug 08, 2011 2:29 pm
I am willing to order the part because the closest ducati dealer is over 300 miles away, so where I am from should not matter. but i have added my location. Saint George, Utah.
PostPosted: Mon Aug 08, 2011 5:28 pm
This is an international group so yes where you are matters on the replies you need. :beer: :beer:
Try Ducati of Omaha,very helpful bunch with lots of parts most Ducati dealers don't want to bother with.
Email or phone
PostPosted: Mon Aug 08, 2011 7:10 pm
The factory petcock sucks. I replaced mine with a better one. Make sure you get the one with the side outlet. the down outlet won't clear the frame.
1986 Guzzi BOTT Racer
PostPosted: Tue Aug 09, 2011 1:18 pm
Turin, as several other old bikes used this kind of fuel petcocks do you happen to know thead size ?
PostPosted: Tue Aug 09, 2011 8:58 pm
I don't know the thread size. I pulled the petcock off of my moto guzzi and matched it up against the stock petcock. Exact same nut, width thread size and count etc. The new petcocks fuel passageway looks larger/ flow more fuel, and the guzzi petcock has a much larger filter. It's worked great so far.
PostPosted: Sat Aug 13, 2011 3:21 am
Thank you all for the help it is very much appreciated. :thumbup: :thumbup: :thumbup:
PostPosted: Sat Aug 13, 2011 7:31 pm
forgot to note, you'll want to leave it on the reserve position, or remove the plastic tube underneath the filter screen.
