| got the paso up & running so one more is alive & well http://ducatipaso.org/forum/viewtopic.php?f=1&t=4997 |
| Author: | bobst2 [ Wed Aug 10, 2011 1:21 pm ] |
| Post subject: | got the paso up & running so one more is alive & well |
i was expecting a disaster but i bought it anyway the price was right. i took it home and threw it on the hoist and took it apart. well serviced the engine it only has 13000miles(oil.belts.etc) serviced all the brakes & suspension. put a new battery & chain & sprockets & a clean & kit in the weber. so i took her out for a ride on saturday and she ran & performed fairly well. the brakes were a little soft will bleed them again. might need to put a kit in the master & replace the lines anyone know where to get kits |
| Author: | paso750 [ Wed Aug 10, 2011 2:38 pm ] |
| Post subject: | Re: got the paso up & running so one more is alive & well |
Wow a complete overhaul in only two weeks ? That must be record breaking. Did you also change tires, grease the steering head bearings, swingarm axle and linkage ? There are several manufacturers for brake lines ie Venhill, Goodridge, Galfer, HEL, Cobra, LUCAS etc. I`d take braided lines that have a heat shrinking tube cover as lines without that can scratch the fork quite badly. G. |
| Author: | bobst2 [ Thu Aug 11, 2011 1:43 pm ] |
the tires were new original michelin,s came with the bike. i will do alot more serious work like pulling the steering head & swing arm over the winter. i wanted to get it on the running & driveing so that i could evaluate the rest of the bike. already i had to heli coil the swing arm axel clamp threads already. i also ordered wheel bearings for the rear wheel i also found a brand new set of conti alloy pipes for it, they should arrive soon & a set of mukuni carbs & manifolds. but i think i have the weber fairly close i dont experence any serious bog it,s a little rich at an idle. i was luckey the bike was totaly complete & stock with low milage & came with a ton of spare new parts.its the only reason its on the road so quickly and two weeks with a fair bit of time spent out in the shop
| Author: | jfiore [ Thu Aug 11, 2011 9:15 pm ] |
Check Bevel Heaven for master cylinder rebuild kits - both clutch M/C and brake M/C. |
