ducatipaso.org • View topic - Ohlins Mono Shock Specifications
It is currently Fri Feb 27, 2026 3:22 pm
 Post subject: Ohlins Mono Shock Specifications
PostPosted: Sat Oct 15, 2011 5:32 am
I couldn't scan the spec sheet so I will type out the details. J.
SPECIFICATION CARD SINGLE SHOCK
Code No. DU5082 replaces DU5081
DUCATI 750 PASO 86-88
Total Length 365 mm , Stroke 78 mm
Head 570-05 , Body 1010-07 , Shaft 1002-02, End Eye 1054-03
Internal Spacers 1069-04,-05 , Shaft Jet 1021-03, Adjustment Valve 1055-03
Valve Stop 519-02 , Piston 514-11 , Adjustment Shaft 566-52
Shims :
Compression.....................Rebound
525-38 ..........................530-34
525-38 ..........................525-30
530-34 ..........................525-26
525-30 ..........................530-23
520-26 ..........................525-21
525-23 ..........................525-19
525-20 ..........................530-18
525-19 ..........................578-01 (2 X)
Spring 1099-05 , Preload 25 mm , Spacer and eye 1018-09 , (Spacer and eye 1018-09)
Hydraulic pre-load adjust 1042-04 , Spring Clip 629-01 , Bump rubber 564-01
Gas Valve 603-01
Piston position 35 mm , Rebound Click 18 , Gas pressure 20 bar
*** I used about 200 ml of oil to fill mine,this is not on the spec card ??? ***
*** The second number in the shim part no. refers to its diameter in mm ***
The only 2 things that I found tricky in rebuilding my shock were (1) after removing the shim stacks,there is a large washer that is a very tight fit on the shaft,this has to be tapped back up the shaft (toward the seal end) far enough to expose a snap ring that is rather difficult to remove,and then tapped back off the end of the shaft to allow removal of the seal mounting bush.(2) Filling the shock with oil takes a bit of thought and trial and error so as not to get any air trapped and also get maximum oil volume.I found that about 200 ml of oil put the oil / gas seperating piston at a height where as I pushed the seal assembly into the shock body,I was able to release air through the fill valve and thus get no air in the oil and by the time the seal assembly was in its final position the piston was at the bottom of its travel and ready to be charged with gas.
I'm not sure if this is the correct procedure for filling or correct oil volume but it's now a couple of months since I done it and the shock is working fine.
Some oil is lost as you refit the seal assembly,this is unavoidable.
Hope this helps some of the early 750 owners out there. J. :thumbup: :thumbup:
 Post subject: Re: Ohlins Mono Shock Specifications
PostPosted: Sat Oct 15, 2011 12:32 pm
Thank you very much for sharing! :)
