| underseat electrics. http://ducatipaso.org/forum/viewtopic.php?f=1&t=5104 |
Page 1 of 3 |
| Author: | desmodave [ Mon Oct 03, 2011 5:09 pm ] |
| Post subject: | underseat electrics. |
can anyone post a photo of their set ups please! |
| Author: | jayh [ Tue Oct 04, 2011 6:33 am ] |
| Post subject: | Re: underseat electrics. |
Probably pose more questions than answers,but anyway here you are. J what the hell,while I'm in picture upload mode. |
| Author: | higgy [ Tue Oct 04, 2011 12:57 pm ] |
The 907 The 906 on both bikes the extra leads and fuse holders are for the headlights on the 906 the extra wiring is for the lamda logger both are hicap kit equiped |
| Author: | Desmo_Demon [ Tue Oct 04, 2011 7:18 pm ] |
Here's my '87 P750 as stock (without the wiring upgrade performed, yet)... |
| Author: | desmodave [ Tue Oct 04, 2011 8:53 pm ] |
| Author: | desmodave [ Tue Oct 04, 2011 8:56 pm ] |
| Author: | desmodave [ Tue Oct 04, 2011 9:01 pm ] |
| Author: | desmodave [ Tue Oct 04, 2011 9:04 pm ] |
| Author: | desmodave [ Tue Oct 04, 2011 9:06 pm ] |
| Author: | desmodave [ Tue Oct 04, 2011 9:15 pm ] |
| Post subject: | underseats |
THANKS!!!! for all the photos-a joy just looking well cared for bikes! looks at first i might be missing the earth wire for something? is it the coils mine has one already where they are situated. like the upgrade makes for same place.Also each with a different regulator none same as ihad originally, 2nd rr51 what to do? thanks again-what is that earth??? |
| Author: | jayh [ Wed Oct 05, 2011 3:32 am ] |
Ok Dave ,The black wire on my reg goes through the connector and turns into the green black wire going into the lower connector on the relay that is directly above it ,its a bit hard to see but the top wire into the relay is visible as a bluey/greeny colour,and the lower connector has two wires (both green black going into it,(one of these is connected back to the reg,I can't be bothered tracing the other one at the moment). J. |
| Author: | jcslocum [ Wed Oct 05, 2011 11:24 am ] |
After wiring upgrade. |
| Author: | PasoRoo [ Wed Oct 05, 2011 12:59 pm ] |
Jon, It seems your alternator wiring has melted in exactly the same interesting, chocolatey, way as mine. I recently cut the wires back to where they were halfway decent and crimped new connectors on. It went from this: Downloaded 550 times to this: Downloaded 550 times and a photo of the complete setup for Desmodave: Downloaded 547 times Although the setup is slightly different now because I installed a HiCap kit. Cheers, Mike |
| Author: | Desmo_Demon [ Wed Oct 05, 2011 3:36 pm ] |
| Author: | higgy [ Wed Oct 05, 2011 4:26 pm ] |
Pretty typical of these bikes. Loose wires, corroded connections and burnt up insulation. Takes a little effort but doing the work will greatly increase the performance of these often overlooked bikes. To be fair it is typical of any 20 year old bike,including the rice burners
| Page 1 of 3 | All times are UTC |
