| Mikuni lean spot & pod filter #'s http://ducatipaso.org/forum/viewtopic.php?f=1&t=5164 |
Page 1 of 3 |
| Author: | RADDUCK [ Mon Nov 21, 2011 6:33 pm ] |
| Post subject: | Mikuni lean spot & pod filter #'s |
Hello Team, Did the Mikuni swap a few years back with as set of BDST 38's from a 900SS. I rejetted and reneedled the carbs per Gehard's instructions. with the Y-6 needle jets, 5c19 needles, and the 37.5 pilots. I now have the jet needles in the 5th notch from the top. There is a circlip in this notch, then a plastic washer then a thin metal washer on the needles before they seat on the slides/diaphrams. the reason the needles are set so high (richest setting) is that there was a huge lean spot just off idle that was causing some poor rujnning, popping and backfiring just off idle. Bike idles great and runs really strong from 1/3 throttle and wide open. I have the 2in1 Gio.CA moto Exhaust and a homemade airbox with a 3x5" paper lawnmower filter. We seem to have overcome the lean spot but now run rich everywhere else (friends report gas smell & puff of black smoke when I get on it) and fuel economy has suffered. I've synched the carbs twice. Is there something I've missed? Its totally rideable but it feels like it could be much better. My set of BDST's do not have a fuel mixture screw. It is a fixed setting. I ride at sea level in San Francisco. I am thinking of trying the original 900SS needle jets, needles and pilots and installing K&N or Uni Pod filters. Can you give me your thoughts on the jetting issues and give me the part numbers for the K&N or Uni pod filters you guys are running. As you are probably aware its no fun to take the fairings/tank off these things for the 30th time and I don't want to pull them off just to take measurments. I would like to pre-order the appropriate air filters and have them ready to install next time I change the oil. Thanks! RADDUCK |
| Author: | Foxtee [ Tue Nov 22, 2011 7:21 am ] |
| Post subject: | Re: Mikuni lean spot & pod filter #'s |
Hi Radduck, Sounds similar to the problems I had. I've rejetted with a Dynojet kit for a 750 Monster, but still had the same issues as it state's to turn the air/fuel screw 3.5 turn out for a Monster. Followed the instruction for a 750ss witch state's 2 turns out, now it runs fine. My air/fuel screw's where covered by brass plug's which you drill out carefully to access the screw's. |
| Author: | RADDUCK [ Fri Nov 25, 2011 5:05 pm ] |
Thanks so much Foxtee! I guess Mine has the brass plugs over the mixture screws and I thought that was the end of the road. I don't usually make a habit of exploring around a carb with a drill but I guess this time I'll have to make an exception. I'm going to attack it this weekend. I am positive that is the problem. Wondering though, Logic would have told me that 3.5 turns out would be a richer setting than 2 turns out. In all 4stroke carburetors I've had experience with, the mixture screw is a fuel screw, fully seated closes it and backing it out richens it, sometimes people refer to it as an air screw but that's only the case with 2 stroke carbs. Is this not the case here?Also, are you running Pod filters? Do you recall the particular model number or dimensions of the filters I would need to purchase, inlet, height, style etc? Thanks again and hope you had a great Thanksgiving. |
| Author: | paso750 [ Fri Nov 25, 2011 5:49 pm ] |
Radduck, an airbox is always preferable but an effort. K&N pods that were mentioned in the forum are K&N SN 2530. I have the Unifilter UP4060A. See recent FCR topic in the Sport section. http://www.knfilters.com/search/product ... od=SN-2530 http://www.uniflow.com.au/contents/en-u ... 09%202.pdf (p. 18 in the catalogue) Correct jetting will depend on your setup specially airfilter and exhaust. That`s why in the FAQs I`ve only mentioned the original 750SS and 900SS jetting. When I ran the Mikunis I had a Dynojet stage 1 kit from a 750SS, the modified original airbox with the highest K&N filter and a Gio.Ca.Moto 2in1 exhaust. Stage 1 kit seemed to run better than stage 2. That could`ve been different on other bikes. The Dynojet kit numbers for the 750SS and Monster are different btw. I have a couple of old Mikunis a friend gave me. One should have a Dynojet kit. If he doesn`t want that back you could have it. I just have to ask and disassemble the carbs to see which one actually has it installed. G. |
| Author: | RADDUCK [ Sun Nov 27, 2011 4:47 pm ] |
Hey Gehard, I would love the opportunity to try the Dynojet stage 1 kit if you wouldn't mind parting with it. Please ask your friend if he is ok with letting it go. I will obviously send you funds to cover shipping. On a side note, I talked to one of the factory Honda race mechanics at the Baja 250 a few years ago when I had a few questions about proper jetting for my xr650r dirtbike. (They make a dynojet kit for this bike too). He reccomended against it saying factory needles were soft aluminum but dynojet needles were course and hardened and that they enlarge the brass seats over time. Like a miniture file going up and down every time you open the slide which eventually causes poorer running conditions. Ever heard anything like this before? I've never had one of their kits but I would imagine one would be able to tell just by the finish on the needles. Thanks for your generous offer and all of your great insight. Gunther |
| Author: | Foxtee [ Mon Nov 28, 2011 8:57 am ] |
Just some more info for ya Depending on what main jets you use there's not a lot of difference in the kit's , just which notch and how many turn's on the air/fuel mix screw . I can't find a model on the pod filters Hope the pic helps, my mate with a Guzzi 1000S run's the same filter's with no prob's. Tony |
| Author: | paso750 [ Tue Nov 29, 2011 6:32 pm ] |
| Author: | RADDUCK [ Thu Dec 01, 2011 6:43 am ] |
Go Paso Team. Thanks Gerhard & Tony for all your help here Anyways happy holidays. Will let y'all know how it turns out. |
| Author: | paso750 [ Thu Dec 01, 2011 5:27 pm ] |
parts are on their way. G. |
| Author: | Mc tool [ Sun Dec 04, 2011 11:34 pm ] |
| Author: | RADDUCK [ Tue Dec 06, 2011 3:16 am ] |
MC tool - I too enjoy firearms so we have more in common than the Paso. A little more on this subject... I got my Paso in trade 4 years ago. I rode it 100 miles. Changed out the belts & rollers, got the Webber sorted (well sort of) sourced a set of rubbers, rebuilt the flopping gauge cluster and serviced the front forks with new seals & fluid, orderd a corbin gun-fighter saddle (figured you'd like that). 200 miles into my maiden voyage up highway 1 along the Oregon coast she tried to kill me when I passed a fully loaded logging truck and the countershaft bearing disintegrated (It sounded like a marble in a blender). I towed the whore home and sourced another Paso in Tennesse with some electrical problems through the help of another Paso.org contributor (Thanks Desmo_Demon . I don't know when it appeared but the aluminum this guy fashioned the airbox out of seems to have gotten brittle and a big chunk blew out (could have been one of the many back fires through the carb) to blame with my mixture screws hidden under those brass plugs. Today I ordered a new Yuasa YTX14AH-BS battery and 2 Uni 4245ST pod filters from Phil at Moto Haven in PA. $119 shipped to CA. Gerard's Dynojet kit should arrive in the mean time and by next week the planets will have aligned. Shot a round of sporting clays with a nice browing citori featherweight on Sunday in Morgan Hill with the girlfriend . All in all a great weekend.
| Author: | Mc tool [ Tue Dec 06, 2011 5:33 am ] |
A corbin seat is definatly on the "to get " list I used to do a lot of sporting clays , skeet and DTL, Miroku mod 10. But when the club found out that I could fix stuff and had the right electrical tickets to legally service the chuckers, I wound up spending most of most club days fixin' stuff and not shooting, in the end I just stopped going...... more time to waste on paso's
| Author: | paso750 [ Tue Dec 06, 2011 9:36 am ] |
| Author: | RADDUCK [ Sat Dec 10, 2011 12:14 am ] |
I got them yesterday and yes they were too large. I told Moto Haven when I made the purchase that I needed the 4229ST but he knew it all and insisted I needed the larger ones. They had different part numbers here than what you had provided. Never the less they are in the mail on the way back to him. Just received your package from Santa Dyno Jet. Thanks! Is there some way I can send you payment for the shipping? Thanks again and happy holidays! I may go test ride a 2010 S1000RR tomorrow. They have a beautiful one at the local BMW dealer on consignment with only 2,315 miles on it. Not to worry the Paso is staying in the garage. I just may cheat on it from time to time. |
| Author: | paso750 [ Sat Dec 10, 2011 10:10 am ] |
ok, so they arrived, great. I saw you found the pms, too The 4229ST would indeed be too small as they have an id of 55mm - they were right. 60 mm is what you need. The ones I mentioned came from the catalogue I linked in one of the posts above. G. |
| Page 1 of 3 | All times are UTC |
