| new paso (to me...) stalling.. http://ducatipaso.org/forum/viewtopic.php?f=1&t=521 |
| Author: | nyabinghi [ Mon Jul 18, 2005 8:11 pm ] |
| Post subject: | new paso (to me...) stalling.. |
i just picked up a 750 paso, it has mikuni flatslides in it, it also has a fuel filter/fuel pump setup. it stalls after a few minutes, or after coming off acceleration. i'm assuming it's starving for fuel. can i eliminate fuel pump/filter, and just run gravity feed? it also appears carbs aren't sync'ed. always wanted a paso, neat bike, but as i am quickly learning, all that bodywork is a pain. |
| Author: | nyabinghi [ Mon Jul 18, 2005 8:50 pm ] |
| Post subject: | |
i also noticed, there is no line to the fuel tank return - if not hooked up, in a fuel pump configuration, won't it just flood, or will it put a heck of a lot of undue strain on the pump? |
| Author: | nyabinghi [ Mon Jul 18, 2005 10:56 pm ] |
| Post subject: | |
welp, swapped plugs out, and opened up fuel valve at bottom of tank more, and it ran fine for my 15 mile test ride....wouldn't it be nice if that was the only dilemna.. |
| Author: | redpaso [ Tue Jul 19, 2005 12:08 am ] |
| Post subject: | |
Isn't it just so much fun getting to know a new toy. I am sure it will not be your only dilema. I hope it is but as you will discover the Paso is an idyiosyncratic beast that likes to have you fiddling with it & it is all worth it as the grin from pointing a Paso through your favourite set of twisties is only matched by the grin you get from the attention that they command. Even when surrounded by other exotics, people will want to ask you about your Paso so it is always good to have stories to tell of how you have worked/sorted/restored your treasured beast. Enjoy the bike & keep comming back to the site for all the info & insight that other members have gathered. You are not likely to encounter something that somebody has not experienced before. :thumbup: |
| Author: | jcslocum [ Tue Jul 19, 2005 1:31 am ] |
| Post subject: | Re: new paso (to me...) stalling.. |
