| Carb rebuild question http://ducatipaso.org/forum/viewtopic.php?f=1&t=5433 |
| Author: | ahdoman [ Fri Jun 22, 2012 9:11 pm ] |
| Post subject: | Carb rebuild question |
I'm rebuilding the DCNF. Attached is a picture of the gasket that came with the kit and it looks just like the one I took off. But, is it OK for the gasket to block off the holes circled in red in the second image? http://i1149.photobucket.com/albums/o60 ... /Carb1.jpg http://i1149.photobucket.com/albums/o60 ... /Carb2.jpg |
| Author: | jfiore [ Fri Jun 22, 2012 9:24 pm ] |
| Post subject: | Re: Carb rebuild question |
The gasket doesn't actually block the holes - they are transfer holes, with a channel between them that is cut into the body of the carb. With the gasket in place, there is clearance for air (or air/fuel mixture, I forget the actual flow of the enrichment circuit) to transfer between each set of the two holes. |
| Author: | ahdoman [ Fri Jun 22, 2012 9:44 pm ] |
Thanks for the reply. I noticed that there were matching passages in the casting of the top of the carb and wasn't sure how much volume was needed for the clearance. |
