ducatipaso.org • View topic - Closer spring question
It is currently Mon Oct 26, 2026 7:51 pm
 Post subject: Closer spring question
PostPosted: Fri Aug 17, 2012 2:40 pm
I need to replace the closer spring on my horizontal cylinder. Is it exclusive to the Paso750 or are all of the 2v springs the same?
1988 Red Ducati Paso 750
1999 BMW R1100S
 Post subject: Re: Closer spring question
PostPosted: Fri Aug 17, 2012 6:49 pm
The 750 and 906 & 907 are all the same. The 900SS and Monsters through to the injection models have a different part no. but I think it is a design change and they are interchangeable as the rockers and heads are the same. I believe the later models may use a stronger spring. So any 2V closer spring should fit.
PostPosted: Fri Aug 17, 2012 8:47 pm
Little tip to get the rocker with spring installed; I only use a part from an old lamp, see left item on the picture below. It has a 5mm outer and 3mm internal diameter. Stick the end of the spring in and you've got enough leverage to fit the rocker with spring. Takes about 5seconds.. :thumbup: The right item I use to pull the axles of the rockers. Available at any local hardwarestore.
cheers Léon
Users browsing this forum: No registered users and 31 guests
