| Front Brake Light Switch http://ducatipaso.org/forum/viewtopic.php?f=1&t=5583 |
| Author: | ahdoman [ Wed Sep 26, 2012 4:06 pm ] |
| Post subject: | Front Brake Light Switch |
I've been running down a few electrical gremlins on my bike and yesterday I realized that I don't have any brakelight when I use the front brake. Is the switch mounted at the hand lever? I've been through the manual and it's not clear. Could someone take a pic of how it's mounted? My perches look stock but I dont see how the switch would mount. |
| Author: | paso750 [ Wed Sep 26, 2012 5:31 pm ] |
| Post subject: | Re: Front Brake Light Switch |
follow the brake line from the pump to the splitter at the lower triple clamp. There`s a pressure switch. Check TAV.18 of the parts caatlogue. G. |
| Author: | Brutus [ Wed Sep 26, 2012 8:47 pm ] |
I've recently replaced the stock brakelines at the front with stainless steel lines. Just two lines from the pump to the calipers. Still have to add a micro switch on the ps13 pump lever instead of the pressure switch. Léon |
| Author: | higgy [ Thu Sep 27, 2012 12:22 am ] |
Bevel Heaven has either of the lever mounted switch required when you loose the junction block and pressure switch with braided lines |
| Author: | ahdoman [ Fri Sep 28, 2012 6:17 am ] |
According to Ducati the stock switch has been discontinued. There's a local auto parts store in my area that caters to guys who do a lot with European imports. I took the old switch to them and he pulled a generic one from the shelf. The difference is it had the tapered pipe thread. He ran a 10mm x 1.0 die down the threads, cleaned it up and it works perfectly. Total cost; $22.50. |
| Author: | whitepaso [ Sun Sep 30, 2012 1:17 am ] |
Try here. I believe the one needed is a few up from the bottom of the page. http://www.mgcycle.com/index.php?cPath= ... 0f5503f3fc |
