| Paso 750 & 906 Transmission Components http://ducatipaso.org/forum/viewtopic.php?f=1&t=5632 |
| Author: | gman [ Thu Nov 01, 2012 5:12 am ] |
| Post subject: | Paso 750 & 906 Transmission Components |
Hi All, Can anyone confirm that the transmission components of the Paso 750 & Paso 906 are identical / interchangeable? Looks like I may need to rebuild my Paso 750 transmission and have found one from a 906. Thanks, Gman |
| Author: | Mc tool [ Thu Nov 01, 2012 7:14 am ] |
| Post subject: | Re: Paso 750 & 906 Transmission Components |
It would be the same as a 750 sport , but not a 906. The 906 bottom end is basically from a 851 916 set up where as the paso750/ 750 sport is pantah based |
| Author: | jayh [ Thu Nov 01, 2012 8:23 am ] |
Aussie prices are a joke,try Ed Milich , Ducpower in the states.I have purchased several items from him including a paso transmission,no problems,just the normal two week shipping delay. J. |
| Author: | paso750 [ Thu Nov 01, 2012 9:47 am ] |
P750 5 gears - 906 6 gears. The easiest will be you look for a gearbox from a 750SS (carbed, -96). Get the part catalogues and compare part numbers. G. |
| Author: | Derek [ Thu Nov 01, 2012 9:57 am ] |
The 600SS/Monster will be the same. |
| Author: | angelix [ Thu Nov 01, 2012 1:16 pm ] |
| Author: | Derek [ Fri Nov 02, 2012 10:08 am ] |
Thanks Angelix, that's useful info to know about. |
| Author: | gman [ Sat Nov 24, 2012 11:56 pm ] |
I have found some transmission components on eBay.com Can someone please confirm that these will suit a 1988 Paso 750? "Ducati F1 Paso Late Fine Spline Transmission Cagiva TT2 good late, fine spline output shaft 5 speed tranny - for late Paso, F1B, adn other pantahs. Worked fine when removed. These are a great upgrade for earlier trannys." Thanks in advance! Gman |
| Author: | Speedmade [ Sun Nov 25, 2012 4:34 am ] |
That transmission will fit directly to your motor. This is a much better trans than your original. You will also need the clutch hub from the Sport, as the spline count is different. |
