new member with questions http://ducatipaso.org/forum/viewtopic.php?f=1&t=5682 |
Author: | Dego [ Fri Nov 23, 2012 7:26 pm ] |
Post subject: | new member with questions |
Are they still available? Hi, I'm new on these forums and have a few questions about Pasos. The firs one being the tires. I have 120/80-16 M/C 60T front in excellent shape and 159/80-16 71H rear, to be replaced. 1. Are the sizes right? 2. If not, what should I fit? 3. I've got issues with the Weber carb diaphragm 4. I need new clutch discs, any recommendation? Are Khamma (Germany) ok? If you are not the expert on these general topics, please refer me in the right direction. Thanx |
Author: | paso750 [ Sat Nov 24, 2012 10:07 am ] |
Post subject: | Re: new member with questions |
Hi, as you`re new just some general (unwritten) forum rules. Do check the manuals first and use the forum`s search function. Then please open your own thread unless your questions fit to an existing one. 1. no 2. see user manual or FAQs 3. what`s the question ? 4. Kämna doesn`t make clutch discs. The most common are ADIGE or SURFLEX. G. PS: adding your location to your profile would help |
Author: | pompone [ Sun Nov 25, 2012 10:52 pm ] |
I think these tire sizes are wrong. I use in my Paso 130-70-16 and 180-60-16. I used 150-80-16 and this size is very high tire and the 5th gear is very, very long, and it is very thin and lose grip suddenly when you are inclined. |
