| Cam Specs and Compression ratio http://ducatipaso.org/forum/viewtopic.php?f=1&t=5867 |
| Author: | koko64 [ Mon Mar 04, 2013 9:33 pm ] |
| Post subject: | Cam Specs and Compression ratio |
Hi All What are the cam specififcations for the P750 cams? Are they from the F1? Also, what is the compression ratio of the pistons? F1 (10:1)? Cheers |
| Author: | paso750 [ Mon Mar 04, 2013 9:56 pm ] |
| Post subject: | Re: Cam Specs and Compression ratio |
Compression ratio is 10:1. Cams are not F1. See p.254 of the smallest file here https://www.box.com/shared/nzfez3vs4q |
| Author: | koko64 [ Tue Mar 05, 2013 2:54 am ] |
Thanks. I have Falloon's revised book. It was good to see the Appendix website for the timing specs. Cheers. |
