ducatipaso.org • View topic - Instrument mounts
It is currently Tue Jun 16, 2026 11:00 am
 Post subject: Instrument mounts
PostPosted: Tue Aug 09, 2005 6:04 pm
The tiny rubber mounts on the instrument panel have come off the pannel. I have tried epoxy and rubber cement, both falled, anyt thougthts?
PostPosted: Tue Aug 09, 2005 7:20 pm
Its normal, that they go broken after 17 years, or so. Take one with You to VERY good rubber parts shop and if its good shop, You will find them there! I make that here in Finland and i managed to find them here. :thumbup:
Finnpaso
PostPosted: Wed Aug 10, 2005 9:21 am
:thumbup:
Superglue (I think it was a Loctite one) worked for me.
 Post subject: Instrument Panel Mounts
PostPosted: Thu Aug 11, 2005 3:36 am
Try the following website: http://www.mcmaster.com. It's the web site for McMaster-Carr, distributors of a variety of hardware and equipment, who will sell to individuals directly.
The item you want is Part Number 9376K112. It is a Vibration Damping Mount, with metric threads M4x0.7, 1/2" tall by 5/8" in diameter, at $1.66 each. They are just a little larger than the originals, but they work just fine. There are also the same item in a slightly smaller size, 3/8" x 3/8", with the same thread, if you prefer. I didn't write down the part number, but you will see it on the web catalog page just above the part number I provided.
McMaster also carries well-nuts, which I also bought from them, but unfortunately they don't carry metric threaded ones. I just replaced all of the standard metric well-nuts with English threaded ones, and replaced all of the mating screws to match.
PostPosted: Thu Aug 11, 2005 4:53 am
Excellent information Jfiore. :thumbup:
Contacts, part numbers, suggestions and general information like this is what makes this site so good. Even if you don't need it now, you can always look back and find it when you do.
Do you guys think it is worth having a section / forum for known fixes / replacement parts ? If so, we could suggest it to Mike. We could nominate someone who regularly uses the site to extract the information from the forums and place it in this area, then we would have all the parts and fixes information in one place.
Just a thought (I'm not trying to make more work for you Mike...)
Paul
PostPosted: Sat Aug 20, 2005 6:20 am
Also you can get some rubber grommets and put a screw through them and screw it directly to the mount , this was the way mine was done before i replaced the instruments with new ones.
Rodney
PostPosted: Thu Aug 25, 2005 11:38 am
I agree with Paul - this site is certainly a wealth of information and these particular postings answer one of the first questions raised during the initial 'strip down' of my new arrival.
I wondered why the clock cluster just pulled out of the recess without much of a struggle! I later noted the little rubber pads still firmly attached to their respective mounting points and with evidence of some form of glue on the clock cluster facing side!
Could anybody inform me if the black foam rubber 'frame' is the original design fitment as the clocks are just a snug fit within the foam, (obviously fixed to the sub frame via the threaded rubber mounts that should be bonded to the cluster of course)!?
I will be taking the cluster apart, (at some point in the future), to clean and rennovate it, (replace lamps, etc), and to check/repair the Paso's infamous clock!
I will be compiling a list of all of my experiences, (good and bad), on my web site and I would hope that, (despite a definite lack of mechanical engineering experience), my electronic skills will provide some support for other members of the group as I continue my project.
I just hope that the final chapter doesn't see us both winding our way towards the local scrap yard!
PostPosted: Thu Aug 25, 2005 6:42 pm
PostPosted: Sat Aug 27, 2005 8:04 pm
Thanks guys, this is fantastic. Just got the bike on the road and I am very pleased with ride. I think it would be great to have a page dedicated to parts.
