| Dead Ignition Pickup http://ducatipaso.org/forum/viewtopic.php?f=1&t=6000 |
| Author: | RADDUCK [ Fri Apr 26, 2013 9:40 pm ] |
| Post subject: | Dead Ignition Pickup |
Hello Gentleman, The ignition pick up that Fires the Vertical Cylinder on my 87 Paso 750 has shit the bed. I'm wondering if anyone has a suitable replacement on hand and if they should be replaced as a pair. Let me know! Thanks! Radduck 415.920.3031 |
| Author: | brad black [ Sat Apr 27, 2013 9:29 am ] |
| Post subject: | Re: Dead Ignition Pickup |
for kokusan boxes? electrexworld sell them, p8 is the #. not the same resistance as std, works fine when fitting just one. need to be soldered into the original wiring, but there is a solder sleeve just at the pick up to make it easy. wires are also reversed, or reverse them at the box connector to make installation easier. |
