It is currently Wed Oct 28, 2026 7:44 am
 Post subject: Dead Ignition Pickup
PostPosted: Fri Apr 26, 2013 9:40 pm
Hello Gentleman,
The ignition pick up that Fires the Vertical Cylinder on my 87 Paso 750 has shit the bed. I'm wondering if anyone has a suitable replacement on hand and if they should be replaced as a pair.
Let me know!
Thanks!
Radduck
415.920.3031
RADDUCK
02 Honda RC51 SP2
87 Paso 750 - Dropped but ride-able
03 Triumph Bonneville - Basket case (resto in the works)
88 Porsche 911 Carrera
04 Subaru STI
 Post subject: Re: Dead Ignition Pickup
PostPosted: Sat Apr 27, 2013 9:29 am
for kokusan boxes?
electrexworld sell them, p8 is the #. not the same resistance as std, works fine when fitting just one. need to be soldered into the original wiring, but there is a solder sleeve just at the pick up to make it easy. wires are also reversed, or reverse them at the box connector to make installation easier.
