| D@mnit!! Mirror replacement.....just the mirror glass. http://ducatipaso.org/forum/viewtopic.php?f=1&t=6008 |
Page 1 of 2 |
| Author: | Bad Cornflakes [ Tue Apr 30, 2013 4:19 am ] |
| Post subject: | D@mnit!! Mirror replacement.....just the mirror glass. |
Anybody know where my dumb@ss can get a new piece of mirror glass to replace the piece I just dropped?
| Author: | Mc tool [ Tue Apr 30, 2013 4:48 am ] |
| Post subject: | Re: D@mnit!! Mirror replacement.....just the mirror glass. |
Ha ha ( Nelson Muntz ) I just had a measure up and mine are about 98mm for the actual mirror so I figure that they are a 100mm or 4" in diameter mirror . Why not go get a ( not to ) cheap 4" mirror and take the glass out of it. The ole Paso mirrors , the glass is set into a plastic insert , with the swivel bit on the back , and the whole thing is held in by 1 screw that hides behind the blinker reflector . dig the broken glass out ( practice w/shop safety , its no fun having sharp implements removed from your body ) and using a couple of blobs of silicone sealer stick the new bit of glass in. I can post some pix if you want as I just happen to have a mirror in bits in preparation for painting. Hamish |
| Author: | Bad Cornflakes [ Tue Apr 30, 2013 5:13 am ] |
Yeah, I had my blinkers apart a few weeks ago and had taken the screw and the mirror out. I then placed the mirror back into the blinker assembly, without replacing the screw, and set it on the workbench. When I picked it up today to re-assemble everything the mirror fell to the ground, shattering the glass. Luckily, the whole thing popped out of the plastic insert. No digging required. Yay for me!?!? |
| Author: | fasterdammit [ Tue Apr 30, 2013 2:45 pm ] |
Yeah, one of mine shattered a while ago - at least 9 years ago, now that I think about it - and I just measured the good one and had a local glass shop cut me a new one. 100mm/4" is what I used too. I don't think it cost me $5 and haven't had a problem since. |
| Author: | Jeffreyt [ Fri May 03, 2013 10:17 pm ] |
Let me know if you still need a mirror. I may have an extra one in my broken parts bin. How do you get the mirror out of the housing? |
| Author: | higgy [ Fri May 03, 2013 10:26 pm ] |
carefully,its double sided tape |
| Author: | Bad Cornflakes [ Sat May 04, 2013 1:59 am ] |
| Author: | Jeffreyt [ Wed May 08, 2013 2:37 pm ] |
Sorry Jason, I have been searching for that mirror but am unable to find it. I moved here about 10 months ago and am still unpacking boxes. I will let you know if I find it but it's not looking good. Sorry, Jeffreyt |
| Author: | nnnnnnorman [ Wed May 08, 2013 3:50 pm ] |
i might be wrong but i think a morris minor glass is the same size? |
| Author: | Bad Cornflakes [ Wed May 08, 2013 5:20 pm ] |
No problem....I really appreciate you even looking at all! Thanks! I did stop by a craft store yesterday and found a couple of 4" round mirrors for <$3. They are a little thicker but I am going to try one out and see how it works. I will let you know. |
| Author: | Bad Cornflakes [ Wed May 08, 2013 5:21 pm ] |
| Author: | paso750 [ Wed May 08, 2013 5:28 pm ] |
Morris Minor |
| Author: | nnnnnnorman [ Fri May 10, 2013 5:46 am ] |
a very nice example
| Author: | Mc tool [ Fri May 10, 2013 8:31 am ] |
| Author: | persempre907 [ Sat May 11, 2013 8:53 am ] |
Woooooow!!!! I love her!!!!!! Ciao |
