| getting horns to work http://ducatipaso.org/forum/viewtopic.php?f=1&t=6076 |
| Author: | Jeffreyt [ Tue May 21, 2013 12:13 pm ] |
| Post subject: | getting horns to work |
Anyone have a suggestion on getting more power to the horn(s)? I removed one horn hoping to get the remaining one to work but it just groans a bit. It works great when jumped directly to the battery. I have cleaned all contacts and replaced some of the wires, the ones that go to the horn directly. Any suggestions? Jeffreyt 1987 Paso |
| Author: | ducinthebay [ Tue May 21, 2013 7:00 pm ] |
| Post subject: | Re: getting horns to work |
Put in a relay. That's how it is in almost any car, and most motorcycles. Cheers, Phil |
| Author: | Mc tool [ Wed May 22, 2013 6:23 am ] |
Some horns have a small screw on the back of them that can be tweeked to "tune " the horn , but if yours goes ok when wired to the battery ckeck that it is earthed properly and also check the voltage to the horn , if there is not enough volts you are better off finding the problem and sorting it than just chucking a relay at it , which may well get the horn going but you are only hiding the problem which may well come back when the relay starts to not work .Having said that I have a relay on mine and there is a BF set of air horns ready to be bolted on ( if I face them directly forwards they will add to the braking in an emergency)....... I once ( when young and impressionable ) had an electric compressor ( 120 psi ) , a pressure tank ( old Freon cylinder ) , electric air valve and 4 sets ( 12 horns ) of horns on my car , scared the shit outa heaps of people but then the cops made me dismantle them on the side of the road...... good times
| Author: | Jeffreyt [ Thu May 23, 2013 12:19 am ] |
Thanks for the two horny guys. I'll look into the relay but I think the problem may be in the switch. |
| Author: | Mc tool [ Thu May 23, 2013 3:23 am ] |
| Author: | fasterdammit [ Thu Jun 20, 2013 2:15 am ] |
I "fixed" mine with one of : Much louder than the stocker and fits right in the same place. Liked it so much I put one my Monster too, and that one was working fine ... |
| Author: | higgy [ Thu Jun 20, 2013 10:35 am ] |
