| Which UK grade of brake fluid should I use?? http://ducatipaso.org/forum/viewtopic.php?f=1&t=6161 |
| Author: | Graemer57 [ Sat Jun 08, 2013 10:39 am ] |
| Post subject: | Which UK grade of brake fluid should I use?? |
I need to replace the brake fluid in my 750 Paso but am not sure which brake fluid to use Dot3, Dot4 Dot??? Anyone got advice. Did a very quick search but couldnt see anything Thanks Graeme |
| Author: | 907pasonut [ Sat Jun 08, 2013 11:37 am ] |
| Post subject: | Re: Which UK grade of brake fluid should I use?? |
hi Graeme, I've used Castrol Dot 4 without any problems, some are less prone to moisture contamination...not sure which. |
| Author: | paso750 [ Sat Jun 08, 2013 12:02 pm ] |
use DOT4. It`s boiling point is higher. Also if you look in the owner`s manual it says to use DOT4
| Author: | ducinthebay [ Sat Jun 08, 2013 4:24 pm ] |
Don't use DOT 5. It is not compatible with a system that has use DOT 3 and 4. |
| Author: | Graemer57 [ Sat Jun 08, 2013 8:16 pm ] |
Thanks for the help Dot4 it is then! Graeme |
