ducatipaso.org • View topic - measures Paso 280mm brake discs
It is currently Fri Mar 06, 2026 2:17 pm
 Post subject: measures Paso 280mm brake discs
PostPosted: Mon Sep 12, 2005 12:24 pm
Anyone have at hand the internal diameter, mounting hole diameter, disc thickness and height of the brake disc (the area which is touched by the brake pads.
I have the measures at home but maybe someone is faster. I was just wondering as some Kawasaki brake discs look similar.
Gerhard
PostPosted: Mon Sep 12, 2005 5:53 pm
"height of brake disc" = that measurement, what is touching to pad: 42mm
"inside hole diameter": 136mm
"thickness": 6mm
"distance between screws"(to another side): 154mm
"munting holes": 8mm
Antti :thumbup:
