| measures Paso 280mm brake discs http://ducatipaso.org/forum/viewtopic.php?f=1&t=633 |
| Author: | paso750 [ Mon Sep 12, 2005 12:24 pm ] |
| Post subject: | measures Paso 280mm brake discs |
Anyone have at hand the internal diameter, mounting hole diameter, disc thickness and height of the brake disc (the area which is touched by the brake pads. I have the measures at home but maybe someone is faster. I was just wondering as some Kawasaki brake discs look similar. Gerhard |
| Author: | Finnpaso [ Mon Sep 12, 2005 5:53 pm ] |
| Post subject: | |
"height of brake disc" = that measurement, what is touching to pad: 42mm "inside hole diameter": 136mm "thickness": 6mm "distance between screws"(to another side): 154mm "munting holes": 8mm Antti :thumbup: |
