ducatipaso.org :: View topic - Oil leak
ducatipaso.org
http://ducatipaso.org/forum/
Oil leak
http://ducatipaso.org/forum/viewtopic.php?f=1&t=6496
Author:  plasmid [ Sun Dec 22, 2013 6:23 pm ]
Post subject:  Oil leak
Anyone know what that small screw is for?
Looks like there's oil leaking from there.
The prev. owner had some rubbery epoxy over it which came loose.
paso leak.jpg [128.13 KiB]
Downloaded 226 times
Author:  Brutus [ Sun Dec 22, 2013 11:15 pm ]
Post subject:  Re: Oil leak
I've got the same issue.. Also like to know what they do.
Author:  plasmid [ Sun Dec 22, 2013 11:21 pm ]
Author:  Brutus [ Sun Dec 22, 2013 11:23 pm ]
Yes, it dribbles.
Author:  plasmid [ Sun Dec 22, 2013 11:26 pm ]
Author:  Brutus [ Sun Dec 22, 2013 11:32 pm ]
Author:  ducinthebay [ Mon Dec 23, 2013 3:54 am ]
I always assumed it was the oil line feeding the head and cams. I assumed it was a cross drilled hole, and that was simply a plug. I have a spare head on the bench. I'll dare to take the screw out and see what's inside. There is some Loctite that seals and holds, but I don't know the part number off the top of my head.
Author:  streetsurfer [ Mon Dec 23, 2013 9:52 am ]
Yes, a sealed oil gallery. I was advised not to try and remove them. Too soft. Sealed mine with rtv after a very thorough cleaning and it hasn't leaked.
Author:  Derek [ Mon Dec 23, 2013 10:09 am ]
As stated above it's a blanking plug for an oilway drilling. They are on all the 2V engines and nearly all of them leak sooner or later. Use a thread sealant to keep the oil in.
Author:  plasmid [ Mon Dec 23, 2013 11:45 am ]
Page 1 of 1 All times are UTC
http://www.phpbb.com/
