| solution for clutch slave cylinder oil leak http://ducatipaso.org/forum/viewtopic.php?f=1&t=676 |
| Author: | Max [ Tue Sep 27, 2005 11:42 pm ] |
| Post subject: | solution for clutch slave cylinder oil leak |
you have to switch to Quad Ring seal. This is not a simple O ring. It solves the problem with leakage. There are claims of 45,000 miles on a 906 and still no leaks. I thought of this solution about 15 years ago when I was looking at my Alfa Romeo's slave cylender. I go mine from http://www.protwins.co.uk/ and the part number is Q4210 559N. There are also available in u.s. It is made out of ethylene propylene and withstands high tempratures and works fine with DOT 3 to 5. My slave cylender piston was worn out but the seal does not seam to care. :neener: |
| Author: | jcslocum [ Wed Sep 28, 2005 11:13 am ] |
| Post subject: | |
Also known as "X" ring: http://tinyurl.com/dx5yr Excellent info Max! |
| Author: | nyabinghi [ Wed Apr 05, 2006 2:16 pm ] |
| Post subject: | |
does anyone know which as568a number this is? or a dimension so i can source it from other sources? |
| Author: | nyabinghi [ Fri Apr 14, 2006 5:45 pm ] |
| Post subject: | |
| Author: | cellardoor [ Fri Nov 04, 2011 1:15 pm ] |
| Post subject: | Re: soulution for clutch slave cylender oil leak |
Is there anyway for me to get some of these without buying 50 at a time?? What is the size of the quadring? |
