| Speedo/Tach cables ... same thing? http://ducatipaso.org/forum/viewtopic.php?f=1&t=6766 |
Page 1 of 2 |
| Author: | fasterdammit [ Mon Jun 16, 2014 8:39 pm ] |
| Post subject: | Speedo/Tach cables ... same thing? |
Can anyone confirm or deny whether the speedometer and tachometer cables are the same item? I found the tachometer cable on Stein-Dinse, and it says that part number is a replacement for #037038710, but when I search that number on Ducati Omaha's P/N lookup, it comes up as a speedo cable. Any truth to that? And if not ... anyone have a P/N for the 750 tach cable? |
| Author: | paso750 [ Mon Jun 16, 2014 8:53 pm ] |
| Post subject: | Re: Speedo/Tach cables ... same thing? |
faster just think. How can a cable just connecting to the cylinder head be as long as the one going down to the speedometer drive ? There`s a number mix up. I noticed that long time ago. If ordering one be sure to measure the speedometer cable and its core before buying one as some aftermarket parts are shorter. If it`s too short steering will pull on the complete instrument panel breaking the vibration dampers. |
| Author: | fasterdammit [ Mon Jun 16, 2014 9:10 pm ] |
That's why I thought it was rather odd, myself. (I also knew I could count on you to reply!) But I figured I'd ask the question anyway. I almost ordered one regardless, thinking that at some point I'd need another speedo cable!I also spoke w/ Ducati Omaha, and they gave me the P/N for a '91 SS 750's tach cable : 067038720 ($41.14 USD), although I don't know if that will work for the Paso either. Getting tough, tracking down part numbers. Anybody have the old microfiche parts guides?
| Author: | paso750 [ Mon Jun 16, 2014 10:49 pm ] |
the error is in the original Ducati parts catalogue as you can see. They name #27 rev. counter cable and #26 speedometer cable while it`s the other way around. It looks like the item description and the according part number are correct but position number isn`t. #067038720 might fit but it`s 10cm longer (640mm vs 540mm) which could cause a bend and higher wear. |
| Author: | viper1 [ Tue Jun 17, 2014 2:06 am ] |
I need a speedo cable too! HELP! |
| Author: | paso750 [ Tue Jun 17, 2014 7:14 am ] |
try http://www.bevelheaven.com/ |
| Author: | higgy [ Tue Jun 17, 2014 10:24 am ] |
| Author: | paso750 [ Tue Jun 17, 2014 10:54 am ] |
just fyi #0795.38.627 is 2" longer then the original P750 cable (850mm vs 800mm). The one of the 907ie is 875mm btw. I wonder if noone is actually checking at their local Ducati shop ... |
| Author: | viper1 [ Tue Jun 17, 2014 11:42 am ] |
| Author: | paso750 [ Tue Jun 17, 2014 12:30 pm ] |
have this number at hand 037038710 or they might say nope as soon as you mention "Paso"
| Author: | fasterdammit [ Tue Jun 17, 2014 3:17 pm ] |
| Author: | paso750 [ Tue Jun 17, 2014 4:11 pm ] |
| Author: | fasterdammit [ Tue Jun 17, 2014 5:45 pm ] |
| Author: | paso750 [ Tue Jun 17, 2014 6:24 pm ] |
| Author: | fasterdammit [ Tue Jun 17, 2014 8:28 pm ] |
Now why I hadn't I seen that before now? sigh ... Thanks, G. Saving my butt like usual. , for those looking for it, located among other gems in the thread. |
